Old 10-17-2014, 08:21 PM   #1
SS MoFo
SS MoFo's Avatar
Drives: 2014 SS/RS 1LE
1LE Squat and Dive between stop lights
Damn I like driving my bitchin 1LE camaro around town. I free rev the LS3 to make the next green light and break hard slowing way down to make the yellow turn lights. After about 10,000 miles of this, I noticed a lot more squat / dive. I don't want to lower the ride height but I'm wondering what type of suspension upgrades I need to make the car calm down and drive without the front going up and down all the time.
Should I get higher rate springs or different shocks?
SS MoFo is offline   Reply With Quote
Old 10-17-2014, 08:26 PM   #2
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
Sounds like you are having too much fun with the ride... Lol
ZYBORG is offline   Reply With Quote
Old 10-17-2014, 08:28 PM   #3
Mark T
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav
Mark T is offline   Reply With Quote
Old 10-18-2014, 06:38 AM   #4
VOGGS-LS3-1LE
Angry by Nature
VOGGS-LS3-1LE's Avatar
Drives: 13' Camaro 1SS/RS/1LE/NPP 1 of 76
Check your front struts, sounds like their blow out.
2013 CHEVROLET CAMARO 1SS/RS/1LE/NPP
1 OF 76
Roto Fab CAI
1LE BADGES
VOGGS-LS3-1LE is offline   Reply With Quote
Old 10-18-2014, 12:50 PM   #5
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Go see Mr .Goodwrench ,your still under warrantee .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 10-18-2014, 01:22 PM   #6
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
I don't know why, but my instict tells me to subscribe to this thread.
Camaro Dude is offline   Reply With Quote
Old 10-18-2014, 03:13 PM   #7
SS MoFo
SS MoFo's Avatar
Verified the The Front Struts really are 1LE part numbers.. they aren't making any noise yet. Then thinking I could just max out the rebound dampening for now, I checked for adjustable rebound but didn't find an adjuster at the top of the strut assembly. Can the rebound dampening be adjusted on the 1LE struts?
Possibly 10K miles is all you get before the factory strut / shock dampening fades.
Old 10-18-2014, 04:43 PM   #8
Camaro Dude
Drives: ‘13 1LE
I've always found that typically, OEM struts installed at the factory on many other types of vehicles as well, simply do not last as long as O.E equivalent and/or aftermarket solutions.
I'm always hoping that one day, this streak will end, alas I see this thread here :(.
Old 10-18-2014, 05:30 PM   #9
L99CAMA2011
L99CAMA2011's Avatar
My Bilstein PSs10s with over 20000 miles don't squat of dive at all even at setting number 5 of 10. Over 5 is too stiff and has no dive even from 110 mph braking on road courses. It has to do with the quality of suspension.
Old 10-18-2014, 05:31 PM   #10
GONIF
GONIF's Avatar
As long as you are under warrantee ,let them fix it if that's what it is . Then someday is you still own it and it fails again , upgrade it .
Old 10-18-2014, 05:34 PM   #11
GONIF
GONIF's Avatar
Let's hope not at $1600.00 a set
Old 10-18-2014, 06:05 PM   #12
Camaro Dude
Drives: ‘13 1LE
I agree, but...
Good luck convincing them your shocks fail the bounce test
Old 10-18-2014, 06:46 PM   #13
GONIF
GONIF's Avatar
Originally Posted by Camaro Dude View Post
I agree, but...
If it is bad ,they will fix it ,but you need to give them a shot at it . Or you could give them both a squirt of oil to make them look like they are leaking . And they always replace leaking shocks if you point it out to them. I would not suggest this if they were good ,but if they are truly bad this will end any doubt they have .
Old 10-18-2014, 07:43 PM   #14
Down Shift
Down Shift's Avatar
Drives: 2010 IOM 2SS/RS
No, the 1LE front struts are not adjustable. They are the same strut body/rod/valve system as the standard Zeta struts, just with a different damping curve. They have a lot more damping in them.
The rears are not adjustable either, but they are monotubes (as opposed to twin tube dampers on the SS).
If your front end is bouncing, it is possible your struts have started leaking and lost their gas charge. If you lift up the dust boot and see oil around the top of the strut tube, there is a good chance they are leaking. If you get them off the car and push down on them and they don't spring back, they have lost their gas charge.
As far as durability goes, the 1LE struts should be good for just as long as the standard dampers. They come off the same assembly line and are built using the same components. However, as I said above, they do have a lot more damping in them. That means they get hot faster. Kinetic energy absorbed by the damper is turned into heat . More damping = more energy absorbed.
Your location says Texas. Heat is a damper's #1 enemy. Get your dampers hot enough to char the seals and they will leak. It's easier to cook a damper in Texas than it is up here in the north.
Down Shift is offline   Reply With Quote
