![]() Drives: 2010 camaro SS/RS Join Date: Feb 2013
Maggie vs ecs 1500
So ive read through what seems like hundreds of post about people wanting To know what's better PD or centri. I understand the PD blower will give you more seat of your pants grunt and the centris are the hp number kings. I don't really have any HP goals or any interest in the 1/4 mile. I just like going fast. So my question is, is there a certain mph where the PD blower falls on its face? I would think that the centri would really outshine the PD at 100+ mph. One last thing, I like to make small road trips in my car 2-3 hours of highway time on average. I would think that since the PD make peak boost so low you'd constantly be putting high boost into the engine even just cruising down the highway. Is this correct? And what kind of cruising psi numbers do people see out of the centris?
Thanks for the help guys! - Jake |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Your only under boost once the vacuum drops to a given point meaning hard acceleration.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
PD blower will make no boost at cruising speeds. You have to go 50% or higher with the throttle to get into boost. I got 21mpg on the highway with a Maggie. My maggie would pull to 155 no problem at 10psi. Cant beat a PD blower for a daily driver. Centri has to build boost.
Centri is RPM dependent meaning the more RPM under load the more boost it will build.
![]() Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
Both are great as far as enduring long trips. Elevation and air density will affect performance. Especially humidity. PD blowers are subject more to heat soak. While cruising though, you're not really in boost with a centri until you hit about 2500RPM, so if you're cruising at 70, you're not gonna see a difference in MPG as compared to running N/A. PD blowers are absolutely great for making power down low. No matter where you are in the powerband, once you hit the gas, you will take off. The downside is that once you hit peak boost, that's it. You're not going to accelerate any faster. Centri's can do the same, but you need to be at a much higher RPM level, and as long as you stay within boost when shifting, you'll continue to build boost. Don't expect to take off at a low RPM. Take this into consideration though, as much as I am an advocate of centri blowers, looking at your location, you may want to look into a turbo kit. You'll have a little lag, but environmental factors won't affect turbos as much as they do with S/C. As example, I was tuned at 20 psi at sea level. When I went racing and datalogged, I lost 3 lbs. because I was at a higher elevation where the air is thinner. Blowers like denser air. Turbos don't care because it builds boost off of the exhaust. To compensate for the boost loss, I dropped a pulley size and gained the lost boost back at a higher elevation.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
#6 |
Correct. Like mine only has 2-3psi of boost at 2500
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
At elevation, I think it is silly to do anything but turbos. The fact that they can pretty much make up for the elevation alone is worth doing, plus for your needs, turbos would work perfect.
Nick
Corvette Z06 -1200ish rwhp |
#8 |
Drives: bicycle Join Date: Jun 2014
PD alll the way. I dont like to rev high which centri needs
#9 |
Thanks for all the responses so far! I do reside in Kansas now at about 1100ft so elevation isn't much of a concern sorry that misleading info. One thing I prefer of the turbo or centri is the ability to expand in the future. I don't know if I'll get bored with the 600hp range. With a turbo kit at what psi or HP will I need to put forged internals and lower compression pistons?
#10 |
Also as far as turbos go anyone know any top mount kits that are of quality? If heard and read horror stories about the fastlane single turbo kit on this site. If I went turbo I'd want a top mount. Spending 6k plus on the kit I'd at least like to see it under the hood! And honestly the idea of the turbos under the car concerns me a bit as far as wear and tear
#11 |
![]() ![]() ![]() ![]() Drives: Maggie blown LS3 vette Join Date: Aug 2009
I disagree with this part of your post just a little. Just because the boost isn't going up doesn't mean the power isn't going up. A TVS typically has a pretty flat boost curve. Boost level will vary very little from 2500 rpm on up. Unless the rig is very poorly put together, the power is going to peak near redline. Boost doesn't go up as RPM rises, but power does. Boost doesn't move your Camaro.
#12 | |
![]() ![]() ![]() Drives: All things Turbocharged Join Date: Dec 2010
#13 |
![]() Drives: 2010 Aqua Blue Camaro 2SS/RS Join Date: May 2013
6 hour car ride with a built motor and twin turbos and I got 25mpg
#14 |
Dyno day today. Stock LS3 drive train with full OBX exhaust.
| Tags |
| centrifugal, ecs, maggie, positive displacement, supercharger |
