Old 10-25-2014, 03:12 PM   #1
mrWizard
mrWizard's Avatar
Drives: 2010 Camaro 2SS/RS M6
2010 ss strut is loose and clunking
The front suspension of my 2010 SS has been making a popping or clunky sound over bumps at low speed. I've read about the strut bushing/bearing issue and I know it's my struts in the front.
Here is what the top of the struts look like. How can I tighten them back down?
mrWizard is offline   Reply With Quote
Old 10-25-2014, 04:25 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
How many mile on them? I just replaced mine for 1LE upgrade. 39k and notice a big improvement afterwards.... Mine were not performing well so I did them all... struts and shocks... I know you can pull them off and tighten the bolt but I dont think it will get you much...
Phasteck has a how to video on spring replacement. That will show you how to tighten the bolt up.
-Don
Old 10-25-2014, 04:48 PM   #3
mrWizard
mrWizard's Avatar
-Don
Same mileage, but I don't have the cash to upgrade struts right now. Just looking to tighten everything up. I'll check out the video you mentioned.
Old 10-25-2014, 05:21 PM   #4
hammdo
hammdo's Avatar
Here is the link just in case
https://www.google.com/url?sa=t&sour...DuSAmwjAqUCf5g
Old 10-25-2014, 08:22 PM   #5
mrWizard
mrWizard's Avatar
Nice, thank you.
Old 10-26-2014, 06:00 PM   #6
F-16 Camaro
Drives: 2010 Camaro 2SS Black
Can you link to what you've read about the strut bearing issue please? I've had this clunk and I thought it was my door, but both my front strut caps look exactly like yours...
F-16 Camaro is offline   Reply With Quote
Old 10-26-2014, 08:22 PM   #7
NoPoney
NoPoney's Avatar
Drives: 2011 Camaro SS Convertible
I had clunk in my vert, and it ended up being resonator hitting the cross brace. Dealership shimmed and it is all better.
NoPoney is offline   Reply With Quote
Old 10-27-2014, 07:29 AM   #8
mrWizard
mrWizard's Avatar
Here are 2 threads you can read through, with a bunch of supposed causes
http://www.camaro5.com/forums/showthread.php?t=61687
http://www.camaro5.com/forums/showth...=49036&page=27
Next weekend I'm gonna pull my front struts out and see if it is the mount or bearing/bushing I have been hearing about.
Also, I've realized that there needs to be some room up top in the engine bay, at the strut, because the top portion I have pictured wiggles when you steer. Open your hood and turn your wheel, you'll see them move.
Old 10-28-2014, 01:52 PM   #9
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
That doesn't look much different than mine before or after 1" BMR springs.
I too have a little noise from the passenger front, but everything seems fine so I don't worry about it.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 10-28-2014, 09:50 PM   #10
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
I'm no expert, that doesn't look too unusual. Are you parked flat? Cut the wheels and take a look. Those things move around.
2021 Crush ZL1 1LE
gotroost is offline   Reply With Quote
Old 10-28-2014, 10:22 PM   #11
Down Shift
Down Shift's Avatar
Drives: 2010 IOM 2SS/RS
Those things attached to the top of the strut are the rebound stops. They keep your top mount from being overloaded if there is ever a negative load applied (i.e. you go airborne, or the car gets lifted on a hoist). They should not be tight against the strut tower with your wheels on the ground, they need some room to move.
If the rubber element in the top mount is failing, or your top mount bearing is shot, that is a different issue. you can replace the top mount without replacing the whole strut. You can probably find a local shop to replace the top mount if you pull the strut module out and take it to them.
Down Shift is offline   Reply With Quote
popping sound, strut
