![]() Drives: 2010 camaro ss/rs Join Date: Dec 2009
Complete Built SS Diff with 3:91 Gears
I have a freshly rebuilt diff 0 Miles. The Diff has GM 3:91 Gears, New GM Posi with JRE posi mod, all new bearings and races, & BMR diff Bushings. It was built by the Pyle Bros in Baytown and comes with warranty. Im selling this for $1400
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads ProCharger F1-X Nitrous Outlet Direct Port Fore Innovations Triple Pump on E85 Alky Control Meth Injection ProEFI ECU Stainless Works 2" Headers with Corsa 3" Exhaust RPM 4l80e with Jakes Transbrake BMR Everything with 15" Conversion Zl1 Front Brakes & Carlyle Racing Rear Brake Kit Weld Wheels |
PaPa Smurf
I owe you $1400? 😆
2022 Rapid Blue SS 1LE
Gears are best bang for the buck. It's a difference you can feel.
If needed I'll throw in stock Axel and stock driveshaft.
#6 |
![]() Drives: 2013 ZL1 Join Date: Jan 2010
Man if only you were selling just the gears!!!! Or if I had $1400!!!! Good luck buddy!
#7 |
02pewtersix where have you been. Hadn't seen or heard from you in a while! Thanks and good hearing from you!
