![]() Drives: chevy corvette Join Date: Apr 2014
Speed limiter
There are many high performance cars that have a speed limiter from the factory. Does the Z28 have such a limiter from the factory. If not what is the top speed of the Z28.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
My understanding is the Z/28 is drag limited, not computer limited, at around 175 mph.
![]() Drives: 2014 Z/28 #72 & 2011 Camaro V6 Join Date: Oct 2014
I have been 165mph in mine, just had shifted into 5th and it was pulling very hard. No doubt it would have punched well past 175, for sure not drag limited...the car has Aero for days...I don't think it is top speed limited...I ran out of road or I am sure it would have buried the speedo..
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Unless it's been modified for more power or a lot less drag, I think aero is going to put a halt to things at 180 or maybe a mph or two more. Top speed that is drag-limited is a wall that you can't see from 15 mph back. For a car that's drag-limited to about 170 mph, each of the last 4 mph takes about 900', 1200', 2000', and over a mile to tack on. You can't see that coming at 155, where each added mph comes in every couple hundred feet.
Norm |
#5 | |
#6 |
![]() ![]() Drives: 14 Z/28 0# Join Date: May 2013
around here between exit 3 and 4 north on 684 you can find the top...I suspect exactly what they said it was @177 and then with wickerbill maybe a bit less. I suggest spotters, a few radios and a good scanner...and remember video or it didn't happen...now get to work.
"PTM11" Search & Destroy
#7 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
Standing 1.5, I wonder if you can get close?
#8 |
My guess - you'd be about 5 mph shy.
I'd have a better answer if I knew the Cd (instead of estimating it) and knew the gearing and the HP and torque figures with rpms for both. Then I could run a little sim. Norm |
#9 | |
Moderator.ca
However, what does sometimes happen is a car will be either aero or mechanically limited, depending on which gear its in. When you shift to a higher gear, the RPMs can drop so far that the engine is no longer making enough power to overcome the drag at that speed. It is possible that this is the case with the Z/28. I know it happened with the C6 Z06.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#10 |
Found a few of those numbers and ran it through a sim that can recognize all three of the above mentioned limits . . . and I'm still thinking 182, maybe 183. On the way I got 12.3 @ 116 vs Road & Track's 12.4 @ 115.9 for quarter mile data, so the sim can't be too far off.
I'm not sure where R&T got their top speed from (I think they could have used another mile and a half of straight and level road) or 172 in 5th @ 6925 rpm (I get 168 @ 7000) unless the tires are actually stretching the steel belts and expanding. Norm |
