![]() Drives: 2SS/RS Inferno Orange Join Date: Jul 2009
V-6 guys. Oil change question
I have a SS so I'm not familiar with the engine configuration on the 6.. but Apparently the new Canyon/Colorado trucks have the same V-6 as the Camaro. Just wondering how hard it is to access the filter/drain plug for oil changes? I'd rather not have to take it to a garage and have to have it on a lift and all that crap just for access to the filter and such. My old Dakota I can just lay on the ground, no jack, shimmy underneath and get to the filter and plug without too much problem.
![]() Drives: 2011 CGM 2LT/RS Join Date: May 2011
Not difficult at all. The filter is in the engine compartment, though.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
LLT/LFX engine oil filters are on top of the engine.
Thanks
To answer your question... unless you are only 8 to 10 inches thick, you will need to elevate your Camaro to get under it enough to drain the oil and fit a drain pan under there. Ramps will do.
I used to have a 2012 1LT.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
The filter is right on top I think it's like 24mm or 32mm to remove the filter cap.
#7 |
having FUN now 13.66@101
24 mm
#8 |
Also, use a torque wrench when putting it back on, I think it is 18 ft-lbs.
#9 |
![]() Drives: 2013 2SS/RS M6 NPP Join Date: Dec 2012
GM must not have thought the oil filter location out very well on this 3.6 since it is a cartridge filter for the most part on the Camaro and CTS. But on our Acadia's it is a spin on and in a PITA location if you want to try and change it out hot, since the cat is right there above it, you just about roast your arms getting to the filter. I don't see why they didn't just keep it a cartridge on the Acadia and other LAMDA platform vehicles.
