Old 10-30-2014, 06:52 AM   #1
Cooks ZL1
Drives: 13 Camaro ZL1
anyone with problems with their New solid isolator Supercharger
Seeing if any other ZL1 owners out there are experiencing what I am. Bought a leftover 13 A6 ZL1 with 38 miles on her.when I test drove the car with 38 miles there was a noise coming from under hood. I didn't really worry about it until I found out about the isolator problems and the SC tech bulletin. The noise I heard since day one is the common isolator noise. So at 3600 miles I had my dealer replace SC under bulletin. They did a great job on replacing the SC and had no complaints when I picked her up. I am Very OCD on this car and who works on it. I was a mechanic for years and know all about dealers. For roughly 500 miles no noises and car performed great. Until recently seems like the isolator noise is back. Sounds exactly the same as before. It's been making the noise for a couple hundred miles now. I haven't talked to dealer about it but will take her back in soon.
I am wanting to see if anyone else has a noise on their new Supercharger???
Thank You
Cooks ZL1 is offline   Reply With Quote
Old 10-30-2014, 07:58 AM   #2
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
The same rattle at idle? If so I'd wonder if they replaced it with the same old design instead of the new one. May have been some old stock still on the shelf somewhere. To test it pull the belt off the SC and rotate the SC pulley back and forth rapidly. If you have a little slack and can make it knock doing this you have the old design.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 10-30-2014, 08:13 AM   #3
Jetcop20
Jetcop20
Jetcop20's Avatar
Drives: '13 ZL1 A6
what noise
4100 miles and not a hint of the DREADED SC noise I am really suprised that yours with 38 miles had it...then they change it out with the same type and again 500 miles and poof NOISE....[ATTACH][/ATTACH]
Jetcop20 is offline   Reply With Quote
Old 10-30-2014, 09:40 AM   #4
jaymoo7
jaymoo7's Avatar
Drives: 2013 Camaro ZL1 A6
47k miles and no noise on my 13.
jaymoo7 is offline   Reply With Quote
Old 10-30-2014, 10:20 AM   #5
HDRDTD
Keep in mind that the same TSB that described the process for replacing the SC due to the dreaded marble rattle and extended the warranty to 120k miles, also described the 'flutter' that will still be audible with the new SC at certain rpm's and load levels.
Old 10-30-2014, 11:14 AM   #6
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Yeah, but wasn't that with an M6? Which I read on here was why they didn't use a solid isolator to start with. The internet. Has to be true, right?
I'm at 12k and still no noise.
Old 10-30-2014, 12:18 PM   #7
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
Why would any of this be funny or unbelieveable?
CAM....ZL1 is offline   Reply With Quote
Old 10-30-2014, 12:51 PM   #8
Russell James
Russell James's Avatar
Have a tech check out the noise with a stethoscope. Maybe an idler pulley knocking? Also just to make sure, see if the supercharger part number put on is the one in the bulletin.
Old 10-30-2014, 03:48 PM   #9
eodtech72
EOD
eodtech72's Avatar
Drives: 2015 ZL1
I had mine replaced about a month ago and it's become more noisy than the original. And it's not in 2 or 3 gear low rpm under load as the flutter bulletin describes. Mine is noisy at idle and unlike the original I can hear it inside the cabin. My dealer reported this to GM and gave me a case number. So far the dealer is being told that GM is aware that the new ones are making noise too and have no current direction/fix. I'll be checking again at the end of the week since I've been waiting for over 3 weeks for an answer from GM.
Is there a different part # for the newer supercharger? I'd like to check that out.
eodtech72 is offline   Reply With Quote
Old 10-30-2014, 11:27 PM   #10
Vroom
I have the exact same noise. Its louder then the old version and far more annoying. It makes noise from idle to 1000rpm and it gets worse the hotter the intake is. I have no doubt its going to break at some point.
  • 2013 Victory Red ZL1 - 210K+ miles. Mods: Who needs mods...its a freaking ZL1 - Last car: 2006 GTO
Vroom is offline   Reply With Quote
Old 10-31-2014, 12:35 PM   #11
Iroc-ZL1
Iroc-ZL1's Avatar
Drives: 2013 ZL1 #505
I had my SC replaced about 3 months ago and no noise here, although another buddy of mine had same procedure done and his SC is rattling once again
Iroc-ZL1 is offline   Reply With Quote
Old 11-01-2014, 06:52 PM   #12
Baer383
Drives: 2013 ZL1 Ashen Gray
I replaced my own isolator with a LPE and don't have any noise/flutter,I think some of these noises are random.
Baer383 is offline   Reply With Quote
Old 11-01-2014, 11:38 PM   #13
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 18 ZL1 A10 & 18 2500HD Duramax
34,000 miles with Metco solid isolator and no noise
Procharged 2018 ZL1 A10
2018 2500HD Duramax
TripleBlkZL1 is offline   Reply With Quote
Old 11-02-2014, 02:45 AM   #14
CRTZL1
Banned
Drives: 2013 CRT ZL1
I had mine replaced about 3 months ago as well and checked it again after reading this thread. Put my ear right too the supercharger cover while running and car completely warmed up. No marbling, fluttering, or rattling...
Manual...
Sent from my SM-N900V using Tapatalk
CRTZL1 is offline   Reply With Quote
