![]() Drives: 2012 L99 2SS/RS Join Date: Jun 2014
Whats the difference between stabilitrack competitive mode and having everything off
Whats the exact differences between stabilitrack competitive mode and having the traction control and stablilitrack turned completely off?
I ask because at the drag strip I had wheel spin in both settings but the car ran faster had a little less wheel spin and was less tail happy on competitive mode. Cold slick track btw. |
![]() ![]() ![]() Drives: 2011 2SS/RS Join Date: Feb 2014
I believe competitive mode uses the computer to manage launch and shifting while you're running down the track.
Comp Mode: allows for launch control, and powershifting without pegging your rev limiter Everything off? Zero computer intervention or assistance. The car is likely going to do exactly what you tell it to, for better or worse... |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
Competitive mode just relaxes the nannies a little. You can get the back end out, but it will still save you. With it off, you are on your own.
2011 2SS/RS built 8/24/10
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS L99 IOM Join Date: Aug 2012
L99/A6 do not have launch control.
Traction control off lets the tires spin more freely. Competitive Mode has the nannies in a lesser state. A step away from them being complete off but will still kick in if needed. You will see this more on a road course/AutoX. Both lights on everything is off and now you are in full control from recovering your mistakes or crashing- almost life or death if you are inexperience. StabilityTrac controls the car going into a drift/sideways. Traction Control montiors wheel slip. For drag racing turn off traction control or everything off depending on your skill level. Easy on the gas cuz the car will react different then what you are used to. .... Also from my experience having the car in S mode is what you want to be in. S mode will give you quicker shifts and better throttle. If you are going to get your car tune have them change M mode so it will not bounce off the rev limiter but shift to the next gear. The benefit of that is you can start in 1st gear.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
![]() Drives: '14 Red 2SS/RS/LS3 Join Date: Dec 2013
I have a 2014 SS and when I press the traction control button 2 times it goes into Stabilitrac Competitive Mode. And when I hold the traction control button down for 7-8 seconds, the same Stabilitrac Competitive Mode message is displayed. To me, they both act the same. Launch control if I care to use it or unlimited tire spin if I just side step the clutch.
2014 Red Hot 2SS/RS/M6/NPP/Shifter/Nav/Roof/SilverRallyStripes/Airaid intake/GM StrutTowerBrace/50%-35%tint
#6 |
OP does not have launch control. Manual transmission only.
There is a difference between Competition Mode and everything off if you push the car on a road course or even AutoX
369rwhp/392rwtq
#7 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
With everything on your sports car becomes a prius.
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
#8 |
![]() ![]() ![]() Drives: 2013 Blue Ray 1LS M6 Join Date: Apr 2013
"Whats the difference between stabilitrack competitive mode and having everything off?"
The amount of brown in your wife's/passenger's shorts?
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller Aesthetic Mods Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items |
#9 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
Whats the difference between stabilitrack competitive mode and having everyth...
From my 2013 manual:
Multiple Systems and Modes:
Traction Control System (TCS) When Turned ON:
To turn OFF:
StabilTrak System From the manual ... When Turned ON:
To turn OFF:
Competitive Driving Mode From the manual ...
Launch Control
Engage as follows: Last edited by CrystalRedTintcoat; 11-06-2014 at 03:01 AM. |
#10 | |
#11 |
I don't know. You should check your manual.
-CRT Sent from my iPad using Tapatalk
#12 |
This may help. This summarizes the options for an SS in 2013. Again, always refer to your manual.
http://www.camaro5.com/forums/attach...hmentid=464436 -CRT Sent from my iPad using Tapatalk
#13 | |
![]() Drives: 2014 2SS, Summitt White Join Date: Sep 2014
I need to read the damn owners manual. I didnt know anything about this.... |
#14 |
![]() Drives: '14 Camaro 2SS/RS NPP RRM Join Date: Apr 2014
On the 2014's, competitive mode also tightens up the steering a bit. I much prefer the steering feel in that mode than with the nannies full on.
'14 2SS/RS Red Rock Metallic, NAV NPP
CAI Intake Apex Scoop - to be installed Apex Catch Can - to be installed |
