#1 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
JANNETTY RACING ZL-1 M6 416 HEARTBEAT GOES 10.28 137
We are happy to report while making our fourth pass on the car Jims ZL-1 ran 10.28 ET 137.44 MPH and backed it up with a 10.29 ET 141.89 MPH but the car rolled through the beams and started the clock before I let the clutch go which when you look at the time slip and do the math would have been a 10.1?
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
Nice run Ted. I can't wait to try mine out... In 6 months
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
You got snow already?
![]() ![]() ![]() ![]() Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
I'd love to run in negative DA.
Hell I'm tickled pink when we get as low as 3000
ANGRY Z
No snow. Tracks closed. Could snow any timw
#6 |
![]() ![]() ![]() ![]() Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
That is moving! Think this setup in an Auto with a Higher Stall could go 9.xx?
#7 |
![]() Drives: 2013 ZL1 M6 Join Date: Aug 2013
417, Callies Magnum Crank, Oliver Rods, JE Pistons, Lingenfelter Heads, Comp Cam, Magnuson Heartbeat, 28% Pulley, E-85, Squash Fuel System, Afco, Rotofab, BMR, Hotchkis, Corsa, Kooks, IDA1300's, Comp Cam, Springs, Push Rods, Trunions, Nitrous Outlet, RPM 6-point cage, garage built
#8 |
Impressive,
With a better launch I'd guess you'd be in the 9's already. That is moving and some nice shifting BTW.
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
#9 |
#00193
Drives: 14 ZL1 - 12 CT Join Date: Oct 2014
Good runs! Mods list?
#10 |
Awesome! Are u running the stock driveshaft?
#11 |
Driveline and suspension is all stock from the bellhousing back, the ZL-1 is one tough cookie.
Ted.
#12 |
JRE built 416 stroker
JRE CNC ported Heads JRE rough Idle blower cam Heartbeat supercharger 17 psi ATI superdamper 22% Crank pulley ID-1300 injectors Squash E-85 fuel system E-85 fuel. ARH 2 inch LT headers w or pipes. SCT X4 tuner JRE custom tuning.
#13 |
![]() Drives: n/a Join Date: Apr 2014
What happened to the original engine?
#14 |
It had our 650 RWHP package for about a year.
Came in running like a swiss watch, customer just wanted more. Horsepower is a drug. Thanks Ted.
