Old 11-05-2014, 08:31 PM   #1
intensifi
Drives: '12 2LT Convertible
Lateral Runout or "Why rust on hubs/rotors is bad"
I was having vibration through the pedal (and rear view mirror) when braking from 45mph through 39mph.
I tried re-bedding the pads. That helped a bit. But it did not go away.
I read the updated installation instructions GM posted for the SS Brembo upgrade kit. They made particular mention of thoroughly cleaning the rust off the hubs when upgrading/changing rotors to avoid lateral runout - which causes vibration.
So when I replaced my Brembo calipers yesterday, I spent a lot of time cleaning the hubs & rotors. After the re-install of the rear rotor/caliper set, the vibration problem was gone on the road test.
The moral of the story: Rust on the hubs and rotors is bad.
I learned today there is a kit to attach to a drill to clean the rust off. I wish I'd have had one yesterday. I went through a lot of wire brushes and steel wool!
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 11-06-2014, 09:13 AM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Got a link for the cleaning kit?
Mods:
Old 11-06-2014, 10:42 AM   #3
intensifi
http://3mcollision.com/scotch-brite-...kit-07547.html
Old 11-06-2014, 11:16 AM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Originally Posted by intensifi View Post
Thx
Not bad for around $35.
I'll use this next time I swap out rotors.
I beat most peeps miss this step and complain about brake vibrations...
Mods:
Old 11-10-2014, 08:00 PM   #5
intensifi
Thx
I bet most peeps miss this step and complain about brake vibrations...
Yep. I was one of them.
hub, lateral runout, rotor
