Old 11-08-2014, 05:26 PM   #1
MonteSS
MonteSS's Avatar
Drives: 2010 1SS M6
Supercharged SS - Thinking about headers?
Hey guys, looking for a few opinions here.
My mods are in my sig, and I told myself I was done as 580hp is quite a lot for a DD. But we all know about how long that mentality lasts...
What kind of HP gain can I expect with a good set of headers and hi-flow cats?
Is 25 or so to the wheels a reasonable expectation?
I've been looking into Kooks, and I hear good things about American Racing. It seems like 1 and 7/8" seems to be the size most go with. Any additional thoughts about size?
I have a few grand set aside on top of the headers, incase I start breaking things with this kind of power
2010 1SS M6
10.58 @ 129
790/689
D1 Procharger
Blower Cam
Long Tubes
Alky Control Meth
Tuning by Shane Hinds
Built by STG Motorsports
MonteSS is offline   Reply With Quote
Old 11-08-2014, 05:55 PM   #2
Bo White
Bo White's Avatar
http://www.camaro5.com/forums/showthread.php?t=328817
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 11-08-2014, 09:51 PM   #3
jrpxxii
jrpxxii's Avatar
I have run both the ARH and Kooks and both are excellent choices. I first had the ARH 1 7/8 headers and then went Kooks 2" headers. You cant wrong with either and will get the same power gains from each but I can say the Kooks have a lot better fitment than the ARH. The Kooks fit perfectly so Id recommend the Kooks over the ARH but just my .02
Old 11-09-2014, 08:05 AM   #4
Unreal
Drives: 2006 Z06
I had the opposite experience. Kooks fit fine, ARH fit a bit better. I also like the connector and collector on the ARH better. Plus I'll pay a few bucks to support ARH because of all they do for the community, service, etc.
Nick
Corvette Z06 -1200ish rwhp
Old 11-09-2014, 11:41 AM   #5
ToddB
Drives: 2011 2SS Convertible Supercharged
I went with 2" ARH. They fit very good. Go with 2" right away. In the header test, 2" did better all the way threw the rpm range in torque and horsepower.
ToddB is offline   Reply With Quote
Old 11-10-2014, 08:39 AM   #6
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
I don't think you can go wrong with either.. I went with kooks because I was able to get them coated for the same price as ARH and SS works non coated.. Kooks fit was perfect only needed wife to hold passenger side from bottom while I started bolts because the clearance is less. If your carefull and have a hand you can leave plugs in if not take them out and use the stock gaskets it seems to do better.. Maryland speed seems to be cheapest, and has coupon usually if your a price matcher like me call jegs and summit they will beatem and no ship or tax!
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 11-10-2014, 10:33 AM   #7
Outlaw77
Outlaw77's Avatar
Drives: 2018 Charger SRT 392 F8 Green
Kooks.
Outlaw77 is offline   Reply With Quote
Old 11-10-2014, 10:38 AM   #8
Supercharged Red
Supercharged Red's Avatar
Drives: 2011 Camaro 2SS/RS A6 Victory Red
Kooks from Maryland Speed. I went with 1 7/8. Go with the 2" if you want to go above 600 RWHP
2011 Camaro 2SS/RS A6/L99 Victory Red
SLP TVS2300 Supercharger 6psi & Coil Covers. Roto Fab CAI. RX Catch can ZL1 Fuel Pump
Kooks 1 7/8" LT Headers w/ High Flow Cats Corsa out the back! NT555R 305/35/20
472 RWHP 466 RWTQ 12.11 @ 114.3 MPH 1.81 60' Pacific Raceways Kent, WA 6/6/13
Supercharged Red is offline   Reply With Quote
Old 11-10-2014, 10:39 AM   #9
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
I would go with the Kooks 2" stepped to 2.25"
Then wrap them with DEI Titanium headers wrap for maximum scavenging,
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 11-10-2014, 11:27 AM   #10
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
I went with Kooks also. I've installed 4 sets on Gen 5 Camaro's, the fitment I great and I didn't remove the plugs.
sscamaro is offline   Reply With Quote
Old 11-10-2014, 12:40 PM   #11
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Kooks Stepped here...Love the sound!
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 11-10-2014, 01:13 PM   #12
MonteSS
MonteSS's Avatar
Drives: 2010 1SS M6
Thanks for the info guys, looks like I'll be doing the kooks 2" as I found a pretty good deal on a set of them.
2010 1SS M6
10.58 @ 129
790/689
D1 Procharger
Blower Cam
Long Tubes
Alky Control Meth
Old 11-10-2014, 04:49 PM   #13
eviltech72
eviltech72's Avatar
Drives: 2011 Camaro SS/RS package
Kooks and I get a lot of compliment on the sound.
2011 MIO SS/RS M6- CAI - Kooks LT Header, HF Cats w/ 3in Piping - UDP - PTB - CAM- Hotchkis 1in Lowering Springs - ZL1 Factory Reproduction Rims - Performance Tuned by New Era Performance.
eviltech72 is offline   Reply With Quote
Old 11-10-2014, 05:46 PM   #14
H-E
Drives: 2010 zr1 Camaro 2011 vert
ARH all the way, theres a reason the OTHER headers HAVE to be coated.The car that just ran 7.6xs@nearly 180 mph uses out of the box ARH 2 inch headers.They support us 5th gen guys 110% and the only 100% american made product i know of, hell even there shirts and caps are made in USA..I think that alone should give ARH the nod..If i can help ypu with a great deal on the ARH let me know.....FYI steped headers do ZERO with closed exhaust. .
H-E is offline   Reply With Quote
