Old 11-09-2014, 09:25 AM   #1
ToddB
Drives: 2011 2SS Convertible Supercharged
Fuel dilution of lubrication oil
Fuel dilution of lubrication oil. I did a Blackstone Labs oil test. Every thing was good except I had 3% fuel dilution in the oil. It should be under 2% per there recommendation. Oil was red line 5w 30 and I had 2800 miles on the oil. Car has 15000 miles on it. Thoughts?
ToddB is offline   Reply With Quote
Old 11-09-2014, 09:39 AM   #2
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Do you run a catch can? If not I would think installation of one would help.
Sent from my SM-G900V using Tapatalk
Firefighter is offline   Reply With Quote
Old 11-09-2014, 10:27 AM   #3
ToddB
Yes I had a catch can since car hit 4000 miles.
Old 11-09-2014, 11:10 AM   #4
Unreal
Drives: 2006 Z06
Car running overly rich? Compression and blow by checked?
Nick
Corvette Z06 -1200ish rwhp
Old 11-09-2014, 11:16 AM   #5
Firefighter
I concur...
Old 11-10-2014, 07:44 AM   #6
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Possibly a fuel injector leaking down slightly? Not sure how a catch can could aid this issue. Other than it being connected incorrectly and not allowing the vapors to exit the crankcase.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 11-10-2014, 02:40 PM   #7
ToddB
Any test for a leaky injector?
Old 11-12-2014, 03:27 PM   #8
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Since you don't drive it much, how much time was on that oil?
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 11-13-2014, 12:40 PM   #9
ToddB
Above. 2800 miles.
Old 11-14-2014, 01:19 PM   #10
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
Is their suggestion of the 3% fuel for a cammed car or a stock engine? I would think a cammed car will have slightly more fuel in the oil due to the increased valve lift and duration.
NICK
Lethal Racing is offline   Reply With Quote
Old 11-14-2014, 02:44 PM   #11
ToddB
They recommend under .5 for a stock car
Old 11-15-2014, 08:16 PM   #12
Andy-AMSOIL
Andy-AMSOIL's Avatar
Drives: bicycle
The first question you need to ask, did the file dilution cause the oil to decrease in viscosity?
Send a sample next time to oil analyzers... they have better testing equipment
Andy-AMSOIL is offline   Reply With Quote
