Old 11-09-2014, 09:06 PM   #1
Akquaman
Akquaman's Avatar
Drives: Camaro 2014 RS
Paddle/tap shifter correct use
When using the tap shifter; should I shift gear keeping the gas pedal pressed as normal driving or should the gas pedal be briefly released (as when using manual transmission) just before shifting? What is the correct way to use the paddle/tap shifter? Thanks!
Ps: Haven't dared to use tap shift without releasing the gas pedal yet (seems wrong) and when using it and quickly releasing the gas to shift (as in manual) it doesn't go "right" hearing a slight "delay" like a slipping clutch, kinda... Hope I'm clear enough. Thank you a ton guys!!
Akquaman is offline   Reply With Quote
Old 11-09-2014, 09:07 PM   #2
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
I don't lift.
Homer2 is offline   Reply With Quote
Old 11-09-2014, 09:40 PM   #3
Ace0751
GEN5 Detail
Ace0751's Avatar
Drives: 2011 Synergy Series 2SS Convertible
I keep the pedal down, no need to lift at all. Have to find the sweet spot on when to shift for your car, just like a manual.
Ace0751 is offline   Reply With Quote
Old 11-09-2014, 09:42 PM   #4
Homer2
Homer2's Avatar
5800ish....works for me
Old 11-09-2014, 10:18 PM   #5
Red Jewel RS
Red Jewel RS's Avatar
Drives: 2010 Camaro 2SS
You can use them either way but, the original purpose is the driver to be able to hold your gear until you want to shift or redline and then tapshift with your foot still on the gas. The clutch is automatic.
Red Jewel RS is offline   Reply With Quote
Old 11-09-2014, 11:03 PM   #6
spotticus
Drives: 2014 2SS/RS Camaro
As with a normal automatic transmission, letting off the gas and then back on as the gear is engaging can cause what sounds like slippage. While I've never seen it cause any damage, I can't imagine it's any good for the transmission.
Just keep your foot planted like you would with a normal automatic. The only thing the paddle shifters let you do is control when the gear shifts as opposed to doing it automatically. It's no different (as far as I know) than any other manual mode shifter in an automatic transmission.
spotticus is offline   Reply With Quote
Old 11-10-2014, 06:23 AM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
It's still an automatic, so it controls throttle during shifts. Just keep your foot on the gas!
Rock-It Man is offline   Reply With Quote
Old 11-10-2014, 06:27 AM   #8
NYCamOwner
"Katy"
NYCamOwner's Avatar
Drives: 2014 2LT A6 'Vert
"Keep the pedal to the metal."
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars....
NYCamOwner is offline   Reply With Quote
Old 11-11-2014, 02:20 PM   #9
Akquaman
Akquaman's Avatar
You're the best guys! Honored to hang around you all! Thank you!!
gas pedal on vs. gas pedal off, proper use, tap shift
