Old 11-12-2014, 10:27 PM   #1
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Is this normal?
Have noticed this slightly before but hasn't stuck out/been as "bad" as it did today when I popped my hood to clean my CAI and looked down.
Advice? Input?
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 11-13-2014, 03:06 AM   #2
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
looks like your power steering rack is leaking fluid. keep an eye on your fluid level. going to need to fix
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
Old 11-13-2014, 10:32 AM   #3
bwk1971
Res Ipsa Loquitur
bwk1971's Avatar
Drives: 2013 Camaro SS Vert Supercharged
Does this apply to a 2013, which has electric power steering?
"STREET LEGAL" 2013 Camaro 2SS/RS LS3 Convertible -- 2.9l Whipple Supercharger, CDC SportBar, Cordon CR-1 and MRR M017 wheels, Hex Vents, RPI ZL1 Splitter, CAI, Pfadt Tri-Y Headers, high-flow cats, ZR1 3 bar map sensor, ZL1 fuel pump, 3.875" pulley, ADM FPCM, 1LE PCV Oil Separator Kit, Elite Catch Can, APEX scoop and washer bottle relocation kit, Hotchkis lowering springs, BMR sways, BMR toe rods, BMR trailing arms, 620 rwhp, 564 rwtq, and tuned by Andrew Zurick of Complete Street Performance by way of Maryland Speed.
bwk1971 is offline   Reply With Quote
Old 11-13-2014, 01:57 PM   #4
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
^ Same question
Old 11-13-2014, 08:31 PM   #5
SS Blinder
SS Blinder's Avatar
if im not mistaken, electric means driven by a motor and not the belt. still have a rack correct? please correct me if im wrong. it looks like that is the steering input shaft to the rack of power steering. but like I said, I could be wrong
Old 11-14-2014, 03:25 PM   #6
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Great. So I'll either fix it myself if it's not too expensive, or I'll take it to the dealer as a last resort. Cause I'll know they'll give me shit about my mods. Even though they have nothing to do with this. So it will still be under warranty. Just will be a headache.
Old 11-16-2014, 05:41 PM   #7
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Mine is starting to look like that, did you get it resolved?
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 11-17-2014, 11:34 PM   #8
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Not yet..
Old 11-20-2014, 07:21 AM   #9
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
I have a little bit of weeping in the same spot. I noticed it when I was changing the oil. Yours is much worse than mine though.
Please update this thread whenever you get yours fixed.
TheHorse13 is offline   Reply With Quote
Old 11-23-2014, 03:14 AM   #10
lawdog
Drives: 2010 SSII w RS & Sunroof Yellow
Location: West Suburbs of Chicago, in a Courthouse Somewhere
This is a helpful thread , let's stay on top of this and determine if it is a chronic problem or not !
lawdog is offline   Reply With Quote
Old 11-23-2014, 02:45 PM   #11
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
electric steering is under the dash,there is still some lubrication oil in the steering gear itself any leak is bad, possible warranty issue.Oil comes out moisture gets in
firestone_ss is offline   Reply With Quote
Old 11-23-2014, 03:16 PM   #12
Gee
Silver Ice
Gee's Avatar
Drives: 2011 1LT Coupe SIM
Agreed. Frozen power steering lines dont sound good.
Gee is offline   Reply With Quote
Old 01-28-2015, 04:23 PM   #13
bwk1971
Res Ipsa Loquitur
bwk1971's Avatar
Originally Posted by Jeff_SS View Post
Not yet..
Any further developments on this issue?
Old 01-28-2015, 06:46 PM   #14
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Dealer won't care just take it under warranty
TommyTheCat is offline   Reply With Quote
