![]() Drives: 2010 Black 2LT Camaro Join Date: Apr 2010
2010 2LT high pitch sound when cold
I have been searching around for a few days and can't find a reason, or solution, to this sound I hear.
Since the temperature got cold, I have been hearing a high pitched, whining, sound coming from the engine compartment. I haven't noticed if it gets quieter as the vehicle warms or not, but it doesn't go away. anyone else have this problem, or know what it is. Doesn't seem to have any change in power or function, just curious if I need to be freaking out. Tim |
![]() Drives: 2010 v6 manual Join Date: Dec 2012
Came here looking for the same answer - has only been happening a week or so, and goes away once it's warmed up.
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Record the noise. Belts and pulleys are often much louder when cold and first starting up in the morning, but nobody can give you a definitive answer without hearing the noise
![]() Drives: 2012 Camaro RS Join Date: Nov 2014
I'm having the same problem. I thought I was crazy or something. Mine comes from the passenger side and sounds like a CD spinning. Also came here looking to solve this issue!
