![]() ![]() ![]() ![]() Drives: Iron Lung, Jimmy Join Date: Jun 2009
Radio Wont Come On... Or Go Off
This morning I get in the car and start it up. It cranked unusually slow, but started. Then I get the message 2 Keys Programmed and it wants me to open and close the passenger window. I have no idea what that's about but do as I'm told and the message goes away.
![]() So OK but now the radio screen is blank and it wont come on. All I get is a dull glow. None of the buttons or knobs work except the volume. If I turn the volume knob the screen indicates volume level like normal except of course there is no sound to begin with. Then I try to turn it off. Nothing... still the dull glow. Then I shut the car off and open the door... still the dull glow. All the other interior lights go on and off as normal. Anybody know what's going on? At the very least, what fuse do I pull to cut power to the radio? Car is a 2010 SS. |
376 cubic inches of fun
Low voltage, time for a new battery?
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
I would think the alternator should keep the voltage up when running, unless the battery has a short in one of the cells pulling it down....I am leaning towards the altenator being bad. The radio dying is usually a good sign.
The Bird is the word! |
![]() Drives: 2004 Dodge Ram SRT-10 Join Date: Jul 2014
The only time I got that message is when I disconnected the battery to do the CAI. Sounds like your alternator isn't holding the voltage.
Update
Not wanting to drain the battery while at work I disconnected it for the day. Hooked it up this evening to come home and the car started right up and everything worked normally.
But searching around I found that the 2 keys programmed message seems to come up in low voltage situations which, given that the car was slow to turn over this morning, makes sense. So since I was going to replace the battery anyway, being that it is five years old, I went to O'Reilly's and got a new one. ($185 ![]() Also had them check the alternator... which was fine. Hopefully it was just a matter of a battery on its way out. |
#6 | |
![]() ![]() Drives: 2010 SSII w RS & Sunroof Yellow Join Date: Aug 2009
Location: West Suburbs of Chicago, in a Courthouse Somewhere
#7 | |
#8 |
I bleed green
Late to the thread, but i had a faulty negative battery connection that wouldn't tighten to the post properly. Had to do some grinding to get get it to tighten.
![]() 2011 2SS/RS LS3. Delivered 4/18/11. Solo Axle-back with J-pipes and quads, 35% tint, Yellow trim kit, Showstopper sidemarkers, babied garage queen. 2006 Silverado 3500 6.0, 1993 Pontiac Bonneville SSE |
#9 | |
Just Saw This...
Once they charged it, it tested good. So I thought it was the alternator. I bought the new battery anyway, went home and installed it, then drove the car back and had them test the alternator. It was fine. So now it is one month later and no problems. |
#10 | |
