Old 11-20-2014, 07:28 PM   #1
Jeff 2SS/RS
Jeff 2SS/RS's Avatar
Drives: 2015 Camaro 2SS /RS L99
HP tuner can't access 2015 2SS/RS?
Had the guy with the HP tuner attempt to access and tune my SS, but it will not allow him to access?
Anyone know what's up with that?
Does he need to update his tuner?
Any input would be greatly appreciated.
*TSP stainless 1 7/8" long tube headers
*High flow Cats
*Borla ATAK cat back exhaust system
*Roto-Fab cold air intake
*Custom Dyno Tune by Lethal Racing
*NGK 4177 TR6 Spark Plugs
*Vitesse throttle controller
*Verona Wheels "Satin Black" 20x9/20x10.5
*Michelin Pilot Super Sport Tires 255/40/20- 315/35/20
Jeff 2SS/RS is offline   Reply With Quote
Old 11-20-2014, 10:45 PM   #2
Jeff 2SS/RS
A little more detail, he can access, but can't change the tune, its like it is locked?
*High flow Cats
Old 11-26-2014, 02:12 AM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Does the 2015 have a different PCM? If not then your tuner needs to contact HPT and see what the problem is. According to HPT's website the 2015 is not on there supported vehicles list. The 2014 is and the 2015 Vett is but the Camaro is not listed. That doesn't mean they don't support it. I'm just telling you whats on there website.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 11-30-2014, 09:59 PM   #4
Ivan @ Southwest Speed
2015 ECU is the same E38 in all the 2010-2014 SS/1LE/ZL1 cars.
He needs to update the HP Tuners software on his laptop.
He can also email them and get the beta 2.25.xxx as well if he is having trouble.
William Henn <bill@hptuners.com>
Good luck and keep us posted!
Old 11-30-2014, 10:18 PM   #5
Jeff 2SS/RS
I'm going to bring it to Lethal Racing, it's about four hours from home but I will be passing through the area, I need someone with a little more experience poking around in the brains of my SS L99, plus they have a dyno to get the tune right.
Thanks for posting
*High flow Cats
Old 12-01-2014, 01:44 AM   #6
Thanks for posting
Nick is good to go. Good luck!!
Old 12-10-2014, 10:08 PM   #7
Jeff 2SS/RS
Thanks guys, the custom tune by Lethal Racing made a big difference
*High flow Cats
Old 12-13-2014, 12:07 AM   #8
1KillerSS
1KillerSS's Avatar
What were your dyno numbers?
Build thread
Old 12-13-2014, 10:36 PM   #9
Jeff 2SS/RS
I haven't received my torque number, but the HP was 385 rwhp.
I ask for a graph, still waiting on that email,
*High flow Cats
Old 01-10-2015, 05:01 PM   #10
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
As I found out today, its BS that HP Tuners made me use BETA charged me two credits when I have an unlimited interface.
The good side with bolt ons, the 2015 Camaro 6l80 made 386 RWHP and 406 RWTQ.
check out my instagram page
Tampa Tuning is offline   Reply With Quote
