Old 11-20-2014, 10:04 PM   #1
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
Finally...twin turbos for my LFX
I finally made up my mind and pulled the trigger on the Fabberge twin turbo kit for my 13 2LT/RS. It's been a long time coming! I have 31,000 miles on my car and couldn't wait any longer. To start with I'm going to run the kit on just wastegates which should be about 7psi. Then later i can upgrade to the boost controller and air/fuel gauge and up the boost to 12psi.
Then maybe later on forged pistons/rods and LF3 hpfp and more boost...
Bring on the permagrin!!
edit: I know I started two threads but the other one has a title that makes no sense so I made this one
JantzenOKC is offline   Reply With Quote
Old 11-20-2014, 10:28 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Congrats.
I'll be watching this thread.
Mods:
Old 11-20-2014, 11:28 PM   #3
skulka222
skulka222's Avatar
Drives: 2012 M6 Victory Red Camaro ZL1
Can't wait to see the numbers and how she does, again congrats on the kit, you'll love it
skulka222 is offline   Reply With Quote
Old 11-21-2014, 08:27 AM   #4
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
about time. congrats
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 11-21-2014, 09:14 AM   #5
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Good Luck, will be able to do H2H against the boosted systems.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 11-21-2014, 09:19 AM   #6
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
Keep us updated. This is the same route I want to take myself and with a car with that many miles I want to know how it will turn out. This is my Daily Driver I also want to upgrade the internals if it can handle the extra amount of boost. The setup and the videos of the other cars that have it so far seems amazing. Some issues here and there but it seems worth the risk.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 11-21-2014, 09:45 AM   #7
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Not so many miles, no?
blackswan is offline   Reply With Quote
Old 11-21-2014, 10:20 AM   #8
JantzenOKC
JantzenOKC's Avatar
Yeah I don't know if I'll be getting dyno numbers but I'll definitely be getting 1/4 mile track numbers.
Old 11-21-2014, 10:24 AM   #9
JantzenOKC
JantzenOKC's Avatar
That should be alot of fun, I look forward to running it at the track. I'll have to be ccareful though launching with these toothpick axles. SS rear diff will definitely be on my list.
Old 11-21-2014, 10:27 AM   #10
JantzenOKC
JantzenOKC's Avatar
30,000 miles is nothing, I'm still under warranty lol. And it's been alot of highway miles too. We've taken quite a few trips in the camaro.
Old 11-21-2014, 12:12 PM   #11
HP Turbine
Boosted
HP Turbine's Avatar
I got mine installed at 30,000 also
Old 11-21-2014, 12:19 PM   #12
skulka222
skulka222's Avatar
Got mine installed at 8,000 miles, have put on over 12k since, and its been a blast
Old 11-21-2014, 12:41 PM   #13
Blackchevyroarin
Blackchevyroarin's Avatar
Drives: 2012 camaro 1ls 3.6 LFX
subscribed!
Blackchevyroarin is offline   Reply With Quote
Old 11-21-2014, 12:42 PM   #14
rgrmoreira13
I have almost 25,000 miles on it and by the time I have enough to save for it I will well over 30,000 miles. And my main worry is the internals won't hold because of all that pressure it will handle on a daily basis since this baby is my daily driver.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
