![]() ![]() ![]() Drives: 2011 Camaro Join Date: Apr 2012
Idiot of the week award goes tooooo...
Me!! This morning I was an idiot (nothing new) and backed out of the garage before the garage was all the way up. Luckily I only managed to hit the shark fin. Now it's kinda up lifted off the roof a little and I would love suggestions on how to get it to stick back on. What do I need??
Here's what it looks like.. ![]() Again, very lucky that's all I did.. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
if you didn't damage the roof, then you probably simply need to tighten it down..
the bolt is on the inside of the headliner. Not sure if it is worth the hassle to pull the back of the headliner down to fix it, but I suspect if you don't you may find water seeping into the roofline.
I'm only responsible for what I say, not for what you fail to understand.
Scenic City Camaro
Drives: 2022 Camaro ZL-1 /1974 Firebird 400 Join Date: Jan 2014
I had a loose one on anSUV once and it did leak
2022 Camaro ZL-1, grey
1974 Firebird Formula 400, white https://www.facebook.com/groups/Camaro/ https://www.facebook.com/CRFinTN/?modal=admin_todo_tour |
![]() Drives: 1LT 2011 Camaro M6 Join Date: Sep 2013
Don't feel to bad, did the same thing in my VW Golf years ago, put a couple scratches on the back hatch but messed up the door good, does make on feel like an idiot for awhile though...
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Do you not warm up your car before you leave?
#6 |
No Tags/Habitual Violator
In a hurry right?
Not so bad. A Buddy hooked his front bumper on the garage door rail. Couldn't close the garage door. It was his 87 Grand National. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
Hopefully not.....grossly overrated old wives tale. Engines have less wear when all lubricants are up to operating temperatures. The engine will warm up much faster under a light load then it will warming up, and this less wear. I am not saying do full throttle shots on a cold engine, but slow driving is better than the no load warm up. To each his own....just my $.02.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
I would look into getting some black silicon material rather than have to pull down the whole headliner. Does it feel loose?
#9 |
Drives: black and silver Join Date: Apr 2014
some help
here is the dyi http://www.camaro5.com/forums/showthread.php?t=85635
#10 | |
#11 |
I let the start up rev go down but I keep the garage shut bc my neighbors are still asleep when I leave in the morning, so I opened it and backed out too early like a moron. It's not loose at all it just need to be pulled down..
#12 |
![]() ![]() Drives: 2010 SSII w RS & Sunroof Yellow Join Date: Aug 2009
Location: West Suburbs of Chicago, in a Courthouse Somewhere
HaHa , I did that one time too about 15 years ago, you got off lucky, I needed a new garage door. You can get the fin off without dropping the whole headliner, need to undo the back section and reach in there, if you broke the plastic fin, they are not too expensive, I bought one at the dealer to customize, they are around 48 bucks if I recall. Take it to a body shop and they can swap it out quickly. HOWEVER, the fin electronics matches the stock radio so see if they can take the guts out of yours and put in in the new plastic fin or you have to mess with teaching the radio and that may require a dealer.
#13 |
The Stealth Bumblebee
Drives: Black 2013 2LS Join Date: Aug 2013
With all the horrible blind spots these cars have you managed to hit the shark fin on the garage door? Lol
KILLER BEE
#14 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
it looks like the roof is pushed down a bit
