Old 11-22-2014, 11:09 AM   #1
Don57
Drives a beast!
Don57's Avatar
Drives: Yellow 2014 Camaro 2SS/RS
Question 2015 SS Performance Package?
I'm having a little trouble finding out what the Performance Package on the '15 SS is all about. Can anyone give me a rundown on what it entails? I'm guessing this is more of a track-oriented package?
Don57 is offline   Reply With Quote
Old 11-22-2014, 11:27 AM   #2
Mean Green Z28
Drives: 2010 2SS
the 1LE package? suspension, wheels/tires, rear end, transmission, some aero stuff and the matt black hood wrap.
Typing fat fingered on my GS3...excuse any sfelling mitcakes
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 11-22-2014, 11:38 AM   #3
ElGringo
Drives: 2014 1SS 1LE
Performance package
On GM's web site at least in Canada performance package means 1LE. I think I read somewhere that there are around 200 different components in that package. The high lights are wheels, tyres, strut tower brace, shocks, sways bars, first 4 gear ratios, 3.91 rear end, a bunch of ZL1 suspension parts, steering wheel, shifter, shifter knob, matt black wrapped hood and some other stuff I probably forgot. Yes you do want that option
Do I have one? Hell yes!
ElGringo is offline   Reply With Quote
Old 11-22-2014, 12:26 PM   #4
jwmarler48
Drives: 2014 camaro 1LE RRM
If you need to ask , you probably don't need it im kidding it's a RPO 1LE performance track package. Really makes the camaro a much better car to drive , especially on track! Look in the 1LE section you'll find all you need to know.
jwmarler48 is offline   Reply With Quote
Old 11-22-2014, 12:39 PM   #5
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
You should be sure to test drive one first to ensure it isn't overly stiff for your preferences. In the current Car & Driver comparo, the 1LE is criticized for being overly harsh on the street. And the standard setup does a nice job of controlling a 4,000 lb car.
Consensus is, by definition, a lack of leadership.
Indydriver is offline   Reply With Quote
Old 11-22-2014, 12:52 PM   #6
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
My 14ss has a performance badge under the hood but idk what's different about it.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 11-22-2014, 01:02 PM   #7
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
If you are getting a SS Coupe, its a package you shouldn't pass up, you get a ton for the $3500 and dramatically changes the handling of the entire car.
EXTERIOR/TRANSMISSION/INTERIOR
Exterior:
Forged aluminum ZL1 wheels 20x10 /20x11
Matte Black Hood, front splitter and rear spoiler
Red brembo brake calipers, 4 piston system
Transmission:
Six speed manual is standard
No Automatic transmission for Camaro 1LE
Tremec TR6060 Six speed Manual SS with 1LE Package
First: 2.66
Second: 1.78
Third: 1.30
Fourth: 1.00
Fifth: 0.74
Sixth: 0.50
Reverse: 2.90
Final drive ratio: 3.91
Interior:
Sueded-microfiber wrapped steering wheel and shift knob
OTHER DETAILS
Larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar for awesome body control
Higher-capacity rear-axle half shafts to help with increased horsepower levels of traction
Strut tower brace for improved steering and response
ZL1 20 x 10-inch (front) and 20 x 11-inch (rear) aluminum wheels
285/35ZR20 Goodyear Eagle Supercar G:2 tires front and rear ( same as the front tires for ZL1 )
ZL1 wheel bearings, toe links and rear shock mounts for track performance
ZL1 high-capacity fuel pump and additional fuel pickups for fuel delivery during high-load cornering. (2013 is 1LE only, ALL 2014 SS models have this fuel pump)
1LE Part Numbers:
Strut Tower Brace (LT, SS, 1LE) - 22756880
Wheel Hubs (ZL1, 1LE) (4) - 25954415
Front Coil Spring (SS, 1LE) (2) - 92245257
Front Strut (1LE) (passenger side) - 22812984
Front Strut (1LE) (driver side) - 22812985
Front Sway Bar (1LE) - 22812946
Front Sway End Link (SS, ZL1, 1LE) (passenger side) - 22842515
Front Sway End Link (SS, ZL1, 1LE) (driver side) - 22842516
Rear Shock Mount (ZL1, 1LE) (passenger side upper) - 22836734
Rear Shock Mount (ZL1, 1LE) (driver side upper) - 22836727
Rear Coil Spring (SS, 1LE) (2) - 92195466
Rear Shocks (1LE) (2) - 22812987
Rear Sway Bar (ZL1, 1LE) - 22786260
Rear Sway Bar Endlink (SS, ZL1, 1LE) (2) - 22761221
Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 car conversion)
Rear Toe Link (ZL1, 1LE) (2) - 22845487
3.91 Gears only ( 1LE ) - 22813040
Front Splitter kit ( 1LE ) - 22950575
Wheels 20x10 Black ( ZL1-1LE ) - 22798741
Wheels 20x11 Black ( ZL1-1LE ) - 22798743
http://www.camaro5.com/forums/showthread.php?t=212140
BigBlock69RS is offline   Reply With Quote
Old 11-22-2014, 01:07 PM   #8
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
Yes, check the SS performace package box if you like to shift yourself.
CamaroTom is offline   Reply With Quote
Old 11-22-2014, 01:26 PM   #9
jwmarler48
Exterior:
Transmission:
First: 2.66
Second: 1.78
Third: 1.30
Fourth: 1.00
Fifth: 0.74
Sixth: 0.50
Reverse: 2.90
Interior:
OTHER DETAILS
1LE Part Numbers:
I totally agree!
Old 11-22-2014, 02:31 PM   #10
Don57
Drives a beast!
Don57's Avatar
Ah, I didn't realize this is what gets you the 1LE trim. That makes sense. Thanks for all the info!
performance package
