11-24-2014, 06:07 PM | #1 |
Drives: 2011 Camaro Convertible SS2/RS LS3 Join Date: Jun 2012
Do I Have the Right ATF?
I'm going to swap out the fluid in the manual transmission and rear diff on my LS3.
Everyone on C5 claims ATF (like I've pictured below) is the right fluid for the manual 6 speed on the LS3. But I just checked the owners manual and it said I should use manual transmission fluid. Can anyone confirm I have the right fluid, just for the sake of my conscience, thanks! |
11-24-2014, 06:20 PM | #2 |
drinks virgil's
Drives: 2010 2SS M6 Join Date: Feb 2014
It'll work just fine. Lots of guys run Redline D4 or MTF. Pennzoil has Syncromesh, Valvoline has something, Royal Purple, take your pick.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared |
11-24-2014, 06:51 PM | #3 | |
oldschool69
Drives: 2012 2SS/RS Join Date: Dec 2011
11-24-2014, 06:53 PM | #4 |
11-24-2014, 06:54 PM | #5 |
Drives: 2014 camaro ss ,1967 chevelle ss, Join Date: Sep 2013
i would check the owners manual, but thats just me
11-24-2014, 06:57 PM | #6 |
11-24-2014, 06:59 PM | #7 |
at honda, we have a fluid that is just marked (and i will double check) manual fluid. i have not payed attention to see what weight it is but is not thick like the old 4-speeds take
sorry man, i just looked and my book says...see your dealer
11-24-2014, 07:00 PM | #8 |
Banned
Drives: 2023 Camaro 1SS Join Date: Apr 2014
Cross reference a GM part number for the stuff and find out if Pennzoil Syncromesh MTF meets the GM part number or spec. I'd think MTF would be a better fit than ATF. ATF gets used in automatics, and transfer cases, and power steering pumps.
11-24-2014, 07:42 PM | #9 |
Just in case someone else stumbles onto this thread, there are dozens and dozens of owners who have used and recommend Mobil 1 synthetic ATF. You want the bottle exactly as pictured above, because if it is not DEX VI. Repeat, don't buy the bottle that says it's for DEX VI. Mobil 1 especially benefits the synchros when shifting into 2nd gear in cold weather. I'm sure you've all experience that cold 2nd gear grind.
Here's a good link discussing the benefits of using Mobil 1: http://www.camaro5.com/forums/showth...t=63238&page=2 |
11-24-2014, 07:59 PM | #10 |
Drives: 2015 Camaro SS Join Date: Sep 2011
I called Tremec and was told Mobil 1 ATF for the TR6060 performed the best out of the fluids they tested. Mine actually shifts a little smoother now.
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
11-24-2014, 11:18 PM | #11 | |
drinks virgil's
See, it's shit like this that makes this forum a damned haven of misinformation. If you don't really know, why reply? It's so frustrating.
11-24-2014, 11:52 PM | #12 | |||
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
This handy dandy little slip of paper I got from my dealer (it's one of the last pages of the parts catalog) and it says part# 88861800 is the manual transmission fluid for a V8. A quick Google comes back with this fluid being a replacement for DEXRON III in manual transmissions! OH BOY, DEXRON3 is an ATF! EDIT: Quick bit of history. Dexron III ceased to exist as a licensed by GM transmission fluid in December 2006.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
11-25-2014, 08:46 AM | #13 | |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Even more info floating around out there. But according to GM, the MTF is the old Dexron III. 1.9 Quarts for V6, 4.2 Quarts for LS3, 4.6 Quarts for ZL1 manual trans.
http://www.archivedsites.com/techlin...lubricant.html
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-25-2014, 09:02 AM | #14 | |
Older Than Dirt
From a FAQ on Mobil website
