Old 11-29-2014, 06:35 PM   #1
Verbatim
Drives: '18 2SS 1LE HBM
Carwash with winter tires?
Hey guys,
I've tried some searching but couldn't find much. My 1LE is my daily driver, so I've had the winter tires and wheels on it for a while now up here in frozen Michigan. I have a set of 20x8 stock SS rims with 245/45 20 Blizzaks on all 4 corners. I know we're not supposed to take our cars through car washes with the stock 1LE wheels and tires, but I was wondering if anyone knew if I would be OK now that I have the stock SS rims on there. Are there other limiting factors like the front splitter or something else that would make it risky to do an automatic car wash?
I know I should just find an indoor hand wash to do it, but let's be honest, that is a PITA and I'm much less likely to get it washed if I have to put that much effort in, especially if it will just be salty and filthy again in a day or two.
Thanks in advance for any comments and advice.
Verbatim is offline   Reply With Quote
Old 11-29-2014, 07:11 PM   #2
rodknee
amidst a mid-life crisis
rodknee's Avatar
Drives: 2017 Camaro 1LE
the main thing is the hood wrap. iirc, GM says to not use autmatic carwash so as to not damage the hood wrap.
glad to see someone running the car year round, good luck!
rodknee is offline   Reply With Quote
Old 11-29-2014, 07:48 PM   #3
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
When I had my stock wheels, 20x8 and 20x9, I had no problem in carwashes.
But yeah, most of the "hot wax" things those automatic washes do will make your hood vinyl wrap turn cloudy/foggy.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 12-04-2014, 10:43 AM   #4
Schluney
Schluney's Avatar
Drives: 2014 2SS 1LE
Make sure it's touchless too! Other wise it will likely scratch your hood... Not to mention swirl marks for days
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
Schluney is offline   Reply With Quote
Old 12-14-2014, 09:08 AM   #5
Verbatim
Thanks for the comments guys! Is there anything I could do in the spring to freshen up the vinyl if the wax makes it cloudy?
Old 12-18-2014, 03:06 PM   #6
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
One other item to mention is te chin spoiler ground clearance. The tracks and the stops in most automatic car washes are fairly tall. If you car is lowered you may want to watch that clearance.
Old 12-19-2014, 03:26 PM   #7
Tstormers
Tstormers
Tstormers's Avatar
Drives: Black 2SS/1LE
I take mine through a touchless, trackless carwash in Toronto, without the hot wax options. maybe they have one of these in your area? The one I go to is a Shell (I think you have those in the states). Mines a DD as well
Tstormers is offline   Reply With Quote
Old 12-19-2014, 03:30 PM   #8
RockerBox
RockerBox's Avatar
Drives: 2010 Silverado. Stock height now
I'm a fan of touchless car wash. Whatever I buy will have to go through one.
RockerBox is offline   Reply With Quote
Old 12-23-2014, 08:58 PM   #9
kevinw
Drives: 2013 Black 2 LT vert
OP. even with a car wash, touchless, there will still be that "film" or grime on the car. the car really needs to be hand wiped to really get it all clean, especially salt, etc.
i hand wash my cars on my driveway, even this time of year. i feel like an idiot and i am sure the neighbors want me committed, but a good hand wash is the best way to do it. you have a really nice expensive camaro there, good luck!!
kevinw is offline   Reply With Quote
Old 12-23-2014, 09:13 PM   #10
Scotty D
Drives: 2014 1le 1SS CRMT
I go to a local car wash up here in Boston that's awesome
Scotty D is offline   Reply With Quote
Old 12-23-2014, 09:18 PM   #11
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
I use the ones you pull into, and the wash machine goes around you. That means no issues for clearance or rims. Under car blaster with the deluxe wash.. but they use chemicals so the cloudy hood might be an issue.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
