11-29-2014, 10:05 PM | #1 |
Drives: 2010 Camaro SS2 DeadBLK Join Date: Nov 2010
ECS-YSi intercooler/ADM-Performance trans cooler mounting question
I have about 1/8-3/8" clearance between the condenser and intercooler and the top of the intercooler is fronted by the trans cooler with little more than 1/8" spacing as well....
sorry about pic orientation Ooops. All 3 have large direct airflow surface area but is the spacing between them to small? Has any any played with other remote locations for the trans cooler? Saw one rear mounted but it had a fan unlike my ADM...
11-29-2014, 10:27 PM | #2 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
I'm dizzy... need another drink now !
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
11-30-2014, 12:05 AM | #3 |
Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
That's a creative way to place the cooler. Don't worry too much about the spacing. The cold Canadian air will just pass right through. I think it's good that you have the bottom of the intercooler exposed since the air travels through the bottom more so than the top.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
11-30-2014, 12:24 AM | #4 |
Drives: cars Join Date: May 2011
Closer together is better from a turbulence standpoint although some of those pics look like its touching which would be very bad. Fins + vibration = leak
Make sure that isn't happening. |
11-30-2014, 05:54 AM | #5 |
They aren't touching as I have rubber bumpers stuck in between them at the closest points... But it feel like I should move the trans cooler to some where out back as this seems a little too confined and was wondering how bad it will affect intake temps.
About to have stainless lines made so looking for other options first on the rans cooler location or mount type.
11-30-2014, 10:44 AM | #6 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
My trans cooler is mounted facing down under the front of car with a small wind deflector to force air up thru it.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
11-30-2014, 11:17 AM | #7 |
Drives: 2011 Camaro SS Join Date: Dec 2012
For the ECS kit we usually locate a B&M Hi-Tek in the fender well with a custom bracket underneath passenger headlight.. OR what works really well is the stock C6Z/GS DS oil cooler, you can mount it under the front bumper support and it goes across the entire front. We use this a lot especially for the swap trans cars (4L80E/TH400).
11-30-2014, 02:25 PM | #8 |
Thanks Matt!
Got pics?
12-10-2014, 05:25 AM | #9 |
For more space I removed the ADM trans cooler kit and swap ed it for a Flex-a-lite cooler with stainless lines and russel adapters on the hardlines by the pulley. No metal on metal 1 inch clearness between each.... cooler, intercooler, condenser and radiator.
