Old 12-02-2014, 09:48 AM   #1
ronniels3
Drives: 2010 Camaro SS/RS
Excessive oil in catch can remedy
For those of you that do not have a catch can on your car it is a definitely a must do modification. I installed my catch can after about 10,000 miles on my car because of severe oil consumption. I first installed the RX can which had major issues and there customer service is the worst in the world and it never worked properly as it leaked all the time. I then installed the Elite Engineering catch can which is a work of art. However the catch can would fill to the brim after only a couple of hundred miles of driving. I said that this cant be right. The can is doing its job however why is so much oil passing through? I did a lot of research and spoke to a couple of very close friends of mine Erik and Josh at Lashway Motorsports and we came up with the idea that the baffle located on the underside if the valley cover was leaking air. I really fully don't understand how the valley cover works in conjunction with the PVC system but I said lets change it anyway. I ordered a new valley cover and installed it and drove the car for a very long time. Maybe a thousand miles or so. I then checked the can and there was very little oil in there maybe less than 1 ounce. Its not hard to change maybe an hour or 2 but if you are having this problem the chances are its the valley cover. My car is a 2010. Not sure if other years are affected as well. If anybody has any questions please call me at 954-325-7722. All the catch can does is collect the oil however it doesn't solve the problem.
Thanks
Ronnie
ronniels3 is offline   Reply With Quote
Old 12-02-2014, 10:14 AM   #2
trashmanssd
trashmanssd's Avatar
Drives: Black 14 2SS/1LE/RS 14 Tundra
Nice write up. Yeah I have heard of something similar that most cars where the PCV Valve screws in there is a baffle/cover to keep splash up oil from going in the breather. If that splash guard breaks off splash up oil gets in the breather and dumps tons on oil. Old days the breather would just dump it on the ground which was dead giveaway (oil stains/drips every where you park) now it goes into the intake tract to be burned and fouls the intake and valves very quickly (usually before you can notice the problem). They newer direct injection engines really all should come with a dirty side catch can and emptying it should just be part of doing oil changes.
trashmanssd is offline   Reply With Quote
Old 12-02-2014, 10:22 AM   #3
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
I have also noticed that during the colder months, the oil in the catch can mixes with condensation in the air, and produces a creamy, frothy mess, because of the frothiness, there appears to be more in the catch can.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 12-02-2014, 10:30 AM   #4
ronniels3
I agree.
Old 12-02-2014, 10:31 AM   #5
ronniels3
Don't have that problem here in South Florida. LOL
Old 12-02-2014, 05:26 PM   #6
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
I had the same problem that was remedied the same way!
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 12-02-2014, 05:55 PM   #7
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Never had that issue on my 2010, nor my brother and he's got over 66k miles on his 2010.
Good to know though for future reference.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 12-03-2014, 09:07 AM   #8
ronniels3
Not to sure why or how the valley cover baffle gets screwed up. Mine ate oil since day one. Took a long time to figure out but I am glad I got it fixed. Took about an hour and a half in the garage. The part is $100.
Old 12-03-2014, 09:58 AM   #9
Destructo09
Not too bad, my brother and I both have oil catch cans and haven't noticed any excessive consumption at all, so far I think I can just empty it with each oil change.
2010 2SS
BMR 1" Springs
1LE rear sway bar
SRP Racing Pedals
K&N Typhoon CAI
Old 12-03-2014, 10:01 AM   #10
Mean Green Z28
Drives: 2010 2SS
Great write up and explanation, thanks!
Most every oil catch can story we see here only deals with the catch can doing a great job blah blah blah, here's a post that actually helps the issue, rather than the fix.
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 12-03-2014, 10:56 AM   #11
ronniels3
Thank you. Let me know if you have any questions.
Old 12-03-2014, 01:09 PM   #12
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
Is there are a DIY writeup on how to replace the Valley Cover on the LS3?
Camaro Dude is offline   Reply With Quote
Old 12-03-2014, 01:21 PM   #13
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
In 3 weeks of driving mine gets pretty full.
Rico is offline   Reply With Quote
Old 12-03-2014, 09:50 PM   #14
Mean Green Z28
Drives: 2010 2SS
not much to it. remove intake, replace cover, reinstall intake
Typing fat fingered on my GS3...excuse any sfelling mitcakes
