Old 12-04-2014, 05:43 PM   #1
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
New brake pads
I just installed new Hawk HPS 5.0 pads the other day and it seems like I have to push the brake pedal a little harder to stop. I assumed they should grab right away but needs more effort instead. I only have 27k so the rotors were turned and reused. Any opinions? Thanks
Rico is offline   Reply With Quote
Old 12-04-2014, 09:45 PM   #2
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
bleed the brakes
Tmick5jr is offline   Reply With Quote
Old 12-04-2014, 10:21 PM   #3
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Did you bed the new pads in properly? I don't see why the brakes would need bleeding just from a pad change.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 12-04-2014, 10:25 PM   #4
Rico
Rico's Avatar
Drives: Black SS/RS
I did the recommended steps to bed them. I might have to recheck them this weekend.
Old 12-05-2014, 06:56 PM   #5
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
i said the same thing, until i had the same problem as OP a few weeks ago. i bled them and went back to normal.
Old 12-05-2014, 07:07 PM   #6
Rico
Rico's Avatar
Drives: Black SS/RS
Maybe I need to do this. After driving around today, only more disappointment. I will get this done over the weekend and post my results. Thanks guys for the help.
Old 12-05-2014, 10:12 PM   #7
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
don't worry dude, i felt the same way. i bled them and everything was good. When you compress the pistons to fit the new pad in, your just pushing old dirty fluid back up into the lines. Fresh fluid should do it.
