Old 12-05-2014, 03:02 PM   #1
Schluney
Schluney's Avatar
Drives: 2014 2SS 1LE
Anyone doing any mods over winter hibernation?
I just ordered a set of Trick flow 255 heads. I'm going to mill them .030 which will bump my CR to the 11.4 range also going to have Pat G spec me a cam, have my intake ported and I'm on the BO White list... I also plan to have a custom harness bar made and pick up some driving gear for track days next year! Anyone else have big plans for their 1LE over winter?
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
Schluney is offline   Reply With Quote
Old 12-05-2014, 03:08 PM   #2
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Well, its not a 1LE, just a regular old SS, but I am going to do the Vitesse Throttle Controller, BMR Trailing Arms, Dynamat and Hushmat the interior...
Yours is way better...
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 12-05-2014, 03:52 PM   #3
Cool1LE
Cool1LE's Avatar
Drives: 2014 Blk 2SS/1LE
high flow cats & some engine bay cosmetic changes
Cool1LE is offline   Reply With Quote
Old 12-05-2014, 04:06 PM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Mine also is not a 1LE just a 1SS but I just have a few simple mods planned....
AGP Twin turbo kit 54/56 Turbos
ID850's
Livernois dual fuel pumps
Alky control
FSP custom grind cam
AEM Truboost Controller
Autometer A Pillar pod
BMR Trailing Arms, Rear, Polyurethane Bushings
BMR Toe Rods, Rear, Polyurethane Bushings
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 12-05-2014, 04:51 PM   #5
OzzySS
OzzySS's Avatar
Drives: 2013 2SS/1LE, 2004 Cavalier
ID850's
Alky control
we're doing similar things i've got my kit on the way...did the cam earlier this year, along with the pillar pod and AEM wideband kit. are you going to FSP for your tune? my plan is more along the lines of:
AGP TT S200SX turbos
ECS BAP
kit injector upgrade
AEM fuel pressure gauge for the second pillar pod
Greddy Profec EBC
pfadt tie rods and control arms
speaking of - i'll have some low miles Pfadt Tri-y headers and a yellow roto-fab intake for sale soon if anyone's interested, PM me
Build thread linked in the pic...
OzzySS is offline   Reply With Quote
Old 12-05-2014, 04:59 PM   #6
1KillerSS
1KillerSS's Avatar
ECS BAP
Greddy Profec EBC
Yes Matt from FSP is going to play Santa this year, Ill order all the parts on the 19th of this month. I should have it back first part of Jan.
Ditto on the headers lol
Kooks Stepped headers only two months old!
Build thread
Old 12-05-2014, 05:14 PM   #7
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
No hibernation here, but mods presently on order to help eliminate wheel hop are: BMR rear trailing arms with outer Poly bushing kit, Prothane subframe bushings, JDP Motorsports rear upper control arm bushings. This will be on my car this month.
Op, your going to love the BW throttle body, I installed mine along with CAI Inc. intake a couple of weeks ago, wish that I would have done that months ago.
Old 12-05-2014, 05:28 PM   #8
Schluney
Schluney's Avatar
ID850's
Alky control
That's going to be a awesome build!
Old 12-05-2014, 05:40 PM   #9
SASQUATCHelvis
Drives: 2014 Camaro SS 1LE
I'm planning on re-trimming the door and dash trim pieces in alcantara and leather to match the Recaro sport seats over the winter. I'm also considering getting Bilstein B16 coilovers for the car.
SASQUATCHelvis is offline   Reply With Quote
Old 12-05-2014, 05:42 PM   #10
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
I talking to Matt at FSP as well. They did some stuff on my last Camaro, very easy to work with. My 1LE will be down there early next year, we are in the planning stages of a 1000 RWHP build using an AGP kit and other go fast goodies.
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
Old 12-05-2014, 05:51 PM   #11
Schluney
Schluney's Avatar
Make sure you create a thread for that! I've thought about doing that once my preformance mods are done...
Old 12-05-2014, 11:22 PM   #12
Kendall421
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE
Sure thing!
Solo HF Cats already sitting in the shop
Bo's Ported TB
Under dash red LED's on remote switch
New brighter LED's under hood
JPD separate clutch fluid reservoir (also already in shop!).
Planning to do a good wheel well and under body clean up as well
All 3 sleeping peacefully at the moment though. Mods start in January.
Also have to fix a leaky header on my 69 Z28.
Kendall421 is offline   Reply With Quote
Old 12-06-2014, 02:11 AM   #13
Schluney
Schluney's Avatar
Originally Posted by Kendall421 View Post
Sure thing!
Bo's Ported TB
Beautiful 69 Z/28 my father and I have built a few older mopars and have talked about doing a 69 Camaro next!
Old 12-06-2014, 08:40 AM   #14
1LEMan
1LEMan's Avatar
Drives: 2013 1LE Camaro RS/SS
Going to pull the Ls3 again and check the Comp cam over. Put in CaMotion with shorter LSA. Have a Livernois Stg 2r max now.
Apex springs in the shop now
DeWitt alum rad
Roll bar????
1LEMan is offline   Reply With Quote
