Old 12-07-2014, 05:58 PM   #1
Lateralus754
Lateralus754's Avatar
Drives: 2012 Camaro 2LT RS
Battle of the CAIs
Ordering one tomorrow so I figured I'd ask which intake is king and why.
Here are the contenders:
Cold air inductions (what I'm leaning towards)
Roto-fab
Injen
K&n
BBK
If you were in the same position as me it would be helpful to know which one you went with and why.
Thanks!
2012 Camaro RS 2LT
Vitesse Throttle Controller
Elite Catch Can
Solo Match-X-LFX Cat Back Exhaust
Cold Air Inductions CAI
Lateralus754 is offline   Reply With Quote
Old 12-07-2014, 06:05 PM   #2
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
they all do the same damn thing and make the same numbers. Your gonna get a few of those guy that will tell you that one makes 1 or 2 more horsepower (THAT YOU WILL NEVER FEEL) than the other which really doesn't matter. You can't make a bad choice when choosing any that you listed
Tmick5jr is offline   Reply With Quote
Old 12-07-2014, 06:37 PM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
You forgot one, Vararam.
And the previous post is spot on. they are all good, they will all do well. Just a matter of what you want to see when you open the hood.
I went with the INJEN as it was one of the best on the market when I bought mine, and a few of the others were not availalbe yet. Plus I got it shipped to the house for $273.
I was able to paint it to match my body color.
Below is how my set-up looks and the testing that was done 4 years ago for what was available at the time for the LLT V6.
Good luck.
Old 12-07-2014, 07:38 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
2012 can't have the Injen long tube or the Vararam.
I went with the K&N Typhoon kit (not listed above) because it was half the price of the CAI intake. Slapped the Apex air scoop kit on it and I am quite pleased.
DSX_Camaro is offline   Reply With Quote
Old 12-07-2014, 09:29 PM   #5
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
I think they make a injen long tube for the LFX
Jenner is offline   Reply With Quote
Old 12-07-2014, 09:41 PM   #6
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
I went went Roto-Fab. Liked the paint match, package deal with Elite Can from JDP and dry filter was the clincher for me.
Homer2 is offline   Reply With Quote
Old 12-07-2014, 11:34 PM   #7
dmginc
dmginc's Avatar
Drives: In Circles
the CAI I like best. the cover on the air box means no dirty spot on the hood liner. plus if you add lights to the CAI one it looks really cool.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 12-07-2014, 11:42 PM   #8
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
Here's my CAI brand that I put on along with the Vmax ported TB.
Absolutely love the setup....zero throttle lag and it sounds great!!
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
BBK LT HEADERS 1 7/8”
Tune by DynoSteve via SCTx4 Tuner
One of 82 GF Ragtops built in '15 out of 811 Total
[/SIZE]
theragtopguy is offline   Reply With Quote
Old 12-08-2014, 12:10 AM   #9
intensifi
Drives: '12 2LT Convertible
The Z/28 intake may fit as well (a spacer would be needed since the airtube is slightly bigger). I'm going to an event next weekend where it will be tested.
Update: not gonna happen. sigh.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 12-08-2014, 12:13 AM   #10
JaniMaks
~ Confused ~
JaniMaks's Avatar
Drives: 2014 Camaro 2LS
CAI here too, the response is great and it sounds just fabulous
Never Give In !
CAI Cold Air Intake, MRT V2 (03/01/2016), VTC (03/01/2016)
JaniMaks is offline   Reply With Quote
Old 12-08-2014, 12:25 AM   #11
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
It would take a lot of work to get the z/28 intake to work RIGHT with a v6. I do not recommend doing it unless you're extremely mechanically inclined, tech savy/and or have the ability to make your own random parts to make it work RIGHT. The box will fit, but you will have to come up with your own intake tube setup, and it WILL throw a check engine light if you try to run it with the Z/28 tube in a short amount of time. if you DO manage to get this on your car somehow, make sure you have some way of monitoring fuel trims, as they will more than likely be WAY off.
I guess I should edit this slightly. If you can get it bolted on, it will require a tune to run right, and that's if it can be tuned to run right. It's not going to be an out of the box swap. For the amount of money they are charging for it, you are better off going with something aftermarket that works out of the box.
Jason@JacFab is offline   Reply With Quote
Old 12-08-2014, 01:11 AM   #12
Lateralus754
Thanks guys! Keep the pictures coming, they look great. Any of you guys have videos of how they sound? the CAI only has one video I could find on youtube and the quality was rather poor. Any of you CAI guys have a one?
2012 Camaro RS 2LT
Elite Catch Can
Old 12-08-2014, 06:13 AM   #13
rtcat600man
Actually the INJEN long tube does fit...all good thou.
You are correct about the Vararam thou, I would have thought they made one for the LFX by now. Guess they are not interested?
Old 12-08-2014, 07:12 AM   #14
dmginc
dmginc's Avatar
Drives: In Circles
this is CAI intake and stock exhaust.
