Old 12-09-2014, 02:35 PM   #1
ToddB
Drives: 2011 2SS Convertible Supercharged
Vitesse Throttle Controller
Anyone one with forced induction try this thing? If so your thoughts on it.
ToddB is offline   Reply With Quote
Old 12-09-2014, 03:41 PM   #2
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
I'd think it be scary!
11TexaSS is offline   Reply With Quote
Old 12-09-2014, 03:48 PM   #3
pancherj
Drives: 2010 Camaro SS
Purchased it. Haven't installed it yet. I'd be interested to hear!
pancherj is offline   Reply With Quote
Old 12-13-2014, 04:20 PM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Ill let you know on January 15th! You could use the Eco setting more than the SP setting. But I doubt ill need the controller anymore. Not with Twins, cam, and meth.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 12-16-2014, 12:31 PM   #5
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
For me, I have not bought the controller yet, but will soon. I would want that sucker cranked to the #9 setting though... probably the closest setting to replicate a cable driven TB. I am coming from a couple modified LT1 vehicles with the "old" cable driven TB's, and when my foot goes down, I expect no throttle lag.
RealQuick is offline   Reply With Quote
