Old 08-22-2009, 09:56 PM   #1
PGRICK
Drives: 2010 SS BLK ON BLK
Steering Wheel Shakes
I have noticed a problem recently and was wondering if anyone else has had the same problem. At low speeds turning around corners or turning into my drive way, my steering wheel shakes not all the time but I would say about 60% of the time. It happens if I am turning left or right. The intensity of the shake varies as well, from a light vibration to the wheel vibrating like mad for a couple of seconds while in the turn. Any ideas?
PGRICK is offline   Reply With Quote
Old 08-22-2009, 10:07 PM   #2
ShnOmac
I would start with the simple stuff..Check power steering fluid level just to make sure. Let the car Idle and turn the wheel back and forth a bunch of times then look in steering pump reservoir to see if there is alot of bubbles in the fluid... air in system. If neither of those dont work.... Take it to dealer and let them work on it! There is quite a few things that could cause this in the front end. JMHO
ShnOmac is offline   Reply With Quote
Old 08-22-2009, 11:47 PM   #3
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
you might swing by the dealer and have them check your power steering pump since they are a known problem
firestone_ss is offline   Reply With Quote
Old 08-27-2009, 05:45 PM   #4
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
I posted a similar issue a while back. When I go over speed bumps the steering wheel jerks back and forth. If I'm at a perfect 90 degrees to the speed bump it's fine. The 90 degrees is both front wheels hitting the speed bump at the same time. The fluid level is fine, no power steering pump noise, and no issue steering otherwise.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 08-27-2009, 05:52 PM   #5
n-shane@hotmail.com
n-shane@hotmail.com's Avatar
Drives: 2010 MAROOOOOO
i kind of had this problem with my truck... (silverado) but im hoping i dont have it with the marooooooooo
THIS CAR IS AMAZING!!!!!
n-shane@hotmail.com is offline   Reply With Quote
Old 08-28-2009, 11:53 AM   #6
Big_T
Big_T's Avatar
Drives: 2010 Camaro
When you say vibrating, do you mean twisting left and right on you, or just a general up and down rattle type? Reason I ask is, the other post are describing a power stearing, or handling (Left to right twisting of the wheel) type issue, and a vibration (up and down) is usually an alignment or tire balance type issue.
Big_T is offline   Reply With Quote
Old 08-29-2009, 12:44 PM   #7
Missile Man
Mines left to right, steering wheel slaps back and forth.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 08-30-2009, 12:00 AM   #8
PGRICK
Mine is the same twists left and right. I took it to my dealer today and took the tech out for a ride to show him. Go fiquire every turn I made the damn wheel did not shake!
Old 08-31-2009, 11:52 PM   #9
Missile Man
Murphy.............
2010 Black 2SS L99
Mods:
* CAI Intake
Old 09-01-2009, 11:01 AM   #10
Big_T
Big_T's Avatar
Drives: 2010 Camaro
That sounds more like a stearing related issue then an alignment or tire balance issue. Keep after the dealer, they should be able to duplicate the issue at some point.
Old 09-12-2009, 09:44 AM   #11
Matster
Matster's Avatar
Drives: 2010 2SS/RS IOM/IOM #3625
OK, so mine just started doing the same thing this morning. Making a right hand turn at a stop sign and the steering wheel started to vibrate, felt like the feed back from my Xbox controller in my hands. Did anybody get an answer from a dealership as to what might be causing this to happen?
666 EVIL RWHP BUILT AND TUNED BY SHIFTED PERCEPTIONS INC.(SPi)
416 Forged Stroker, E-Force Supercharger, Blower Cam, Rotofab CAI, Stainless Works 2" LT Headers and 3" Exhaust, LPE ZR1 Twin Disc Clutch, DSS 1400 HP Axles, Pfadt Performance Kit Stage 3.
Matster is offline   Reply With Quote
Old 09-25-2009, 02:21 PM   #12
Matster
Matster's Avatar
Anyone has anyone got an answer for this yet?
Old 10-20-2009, 05:02 PM   #13
Matster
Matster's Avatar
Old 10-20-2009, 11:33 PM   #14
youcmecruzin13
Drives: 2008 Pontiac G5, Camaro nxt 2 mnths
My G5 has done this. It would shake REALLY bad when I braked, and turned, and it was due to warped rotors. Which confused me, considering the car wasnt even a year old. Then about 6 months later it did it when I turned corners at slow speeds, and it was my drive shaft going bad. They fixed it, but not it seems like its starting up again when I slow down. Im selling it within the next 3 months or so to order SS Victory Red W/ White Strips Camaro!!! But that may be your problem! Hope I helped. Get both checked! Both were covered by Bumper to Bumper warrenty.
youcmecruzin13 is offline   Reply With Quote
Steering wheel controls Timberline Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 06-05-2009 10:39 AM
Another new product from DSVcustoms... 2 Tone steering wheel Indpowr Cosmetics and Lighting Modification Discussions 11 05-25-2009 01:08 PM
Steering wheel and shifter material? Blacked Out 5th Gen Camaro SS LS LT General Discussions 13 05-20-2009 03:34 PM
Steering Wheel Pics Request ihc95 Camaro Photos | Spyshots | Video | Media Gallery 9 02-23-2009 03:18 AM
Steering Wheel Radio Controls Bart 5th Gen Camaro SS LS LT General Discussions 19 02-28-2007 01:46 PM
