Old 08-22-2009, 10:52 PM   #1
Rob53
Rob53's Avatar
Drives: 2012 2SS/RS VR Camaro convertible
Early oil change...How do you know that you have reset the oil life system?
For those that have done early oil changes, the manual tells you that after changing the oil, to reset the system. It says that the "CHANGE OIL SOON" message will go off when it's done property. If you change the oil early, that message never appears, so, how do you know that you have reset it?
Rob53 is offline   Reply With Quote
Old 08-22-2009, 10:55 PM   #2
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
You have to go into the DIC and reset it manually.
2023 GMC Canyon Elevation
Old 08-22-2009, 11:35 PM   #3
Rob53
Rob53's Avatar
Okay, thanks
Are the instructions for that also in the owners manual?
Old 08-22-2009, 11:42 PM   #4
LS/V6
LS/V6's Avatar
Drives: 2SS\RS 1LE
Yes it is, but all you have to do is go to the oil life indicator and hold reset.
LS/V6 is offline   Reply With Quote
Old 08-23-2009, 12:21 AM   #5
Rob53
Rob53's Avatar
Thanks guys
Appreciate the help
Old 08-23-2009, 02:09 PM   #6
Bear
Bear's Avatar
Drives: 2015 Green Flash 2SS M6
Originally Posted by Rob53 View Post
Appreciate the help
Thats wierd. On my 07 Torrent when you drop the oil filter the OLM resets itself. Kinda like an idiot proof syste, Not sure if the sensor is near the pan and when theres no oil it resets itself, but I have never reset it, and I check it after every change and its always reset to 100%.
Back in the Game.
Bear is offline   Reply With Quote
Old 08-23-2009, 02:23 PM   #7
97one
97one's Avatar
Drives: 2016 & 1967 Camaro, 2015 Impala, +1
You will see the REMAINING OIL LIFE % change..........From whatever you had to ; 99 or 100% ..........Thats how YOU KNOW you reset it ..........
97one is offline   Reply With Quote
Uncle Ed's Oil Change: W00t? Zabo USA - Great Lakes 0 07-22-2009 04:50 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
