Old 12-10-2014, 01:05 PM   #1
rrang
Drives: 2011 V6 Camaro LT 1 RS
Post Bluetooth confusion
Alright, I have seen a few forums on here about bluetooth, but none of them seem to fit my particular situation. Let start with some clarity on a few questions. My radio has Phone settings when i go to it but then it says Not Available, Is this because my radio does not have bluetooth or is this some error, i saw some fuse thing on the internet could this be my problem? To state my goal i want to A. Keep my stock radio, B. Keep OnStar, C. Gain Bluetooth with the usability of the Mic that is already there for OnStar
1. What is this bluetooth not working due to a fuse issue, i need some clarity.
2. Is there any possible way to keep my factory radio and Onstar while gaining the bluetooth capability.
3. I have spoken with a chevy dealer over the phone but all they did was a quick internet search and I'm not entirely sure they understood what my question was. They said i have to buy this module and put in in and i will have bluetooth is it that simple? http://www.shopchevyparts.com/electr...-92252215.html
My car is a 2011 V6 LT with the RS package . I saw online somewhere that if i have the USB port and Aux Port in the glovebox then i have bluetooth is this true, i don't think so. - Thanks for any help you guys can provide me.
rrang is offline   Reply With Quote
Old 12-10-2014, 01:49 PM   #2
mpiersd
mpiersd's Avatar
Drives: ABM #2041
Have you gone into the sync settings?
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903
ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | RX Catch Can | Mini me
Cortana: 2015 Harley Davidson Road Glide Special
V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer
Gretchen: 1994 Ford F350 Crew Cab Long Bed 4x4
51k mile survivor
Own an Aqua Blue Metallic Camaro?
Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros!
mpiersd is offline   Reply With Quote
Old 12-10-2014, 01:51 PM   #3
rrang
Sync settings? Where do I go to get to those I just purchased the car. I watch online how to do it and it said to go to Config>phone setting>bluetooth... how ever mine goes config> phone settings> not available
Old 12-10-2014, 02:30 PM   #4
mpiersd
mpiersd's Avatar
Drives: ABM #2041
Taken from the 2012 Owners Manual.
51k mile survivor
Old 12-10-2014, 02:31 PM   #5
mpiersd
mpiersd's Avatar
Drives: ABM #2041
I know that when I want to stream music by bluetooth on the radio, I have to select GMMusicConnect under bluetooth setting on my phone, all other times it defaults to GMConnect for phone only.
51k mile survivor
Old 12-10-2014, 02:33 PM   #6
mpiersd
mpiersd's Avatar
Drives: ABM #2041
It si also on page 6-19 of the 2010 Owners Manual, but it is a slightly different procedure with the same end results.
51k mile survivor
Old 12-10-2014, 02:59 PM   #7
rrang
I'll try when I'm back at my car but I think mine doesn't have bluetooth equiped. I know when I go to phone settings it says not available. So if my car is not equipped with bluetooth is there a way I can add it?
Old 12-10-2014, 03:09 PM   #8
mpiersd
mpiersd's Avatar
Drives: ABM #2041
you have to pair the phone to the car before it is available under phone settings on the radio.
follow the directions i posted above and it should sync.
51k mile survivor
Old 12-10-2014, 04:19 PM   #9
rrang
OK when I follow those directions I go to the config menu and on the radio I select phone settings correct. .. however when I select phone settings it says not available. What could cause this?
Old 12-10-2014, 05:50 PM   #10
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
There are potentially two Bluetooth systems, one for audio (PDIM module in center console), and, one for phone (OnStar). The confusion may be coming from that.
sjmautoprod is offline   Reply With Quote
Old 12-10-2014, 06:40 PM   #11
rrang
i cant seem to get either to work for the onstar or the one for music. there is a USB and AUX cable port in the center console but i just don't seem to find bluetooth. i checked the onstar fuse but i am not seeing a fuse for bluetooth in the owners manual. like i said i bought the car monday night, the salesman said it had bluetooth, but he was a Mercedes salesman so take that for what is is worth. I'm kind of getting frustrated with it because one chevy dealer said i should have it and the other one was not sure and said it would be 2 hours before they could check. so if anyone has a sure proof way to know if i have bluetooth let me know. you have a 2010 Lt do you have Bluetooth, i dont think much changed between the 2010 and 11 models if any at all.
Old 12-10-2014, 06:45 PM   #12
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
Is Bluetooth turned on in your phone? If not, then the Bluetooth receiver in the On Star unit cannot see your phone, and cannot pair your phone to the radio.
jeffa is offline   Reply With Quote
Old 12-10-2014, 06:45 PM   #13
sjmautoprod
Drives: '16 2SS
I don't have the OnStar module, and, did not get the car with the audio Bluetooth (I added that later).
If you see GMusicConnect, then, you have the audio Bluetooth. If you don't see GMConnect (mentioned above), I'd say that the car does not have the right equipment for the phone.
Old 12-10-2014, 07:01 PM   #14
rrang
so i would see GMusicConnect on my phone even if i don't start a search on car? I am pretty sure that i dont have it. I have tried everything. What module did you use? i am not going to pay for onstar so i guess it is cool if i lose it.
bluetooth, radio
