Old 12-11-2014, 08:33 AM   #1
JBT
Drives: Camaro
Camaro Now article: A car with 15" wheel conversion.
Was looking at an article in the latest Camaro Now magazine yesterday. Saw that there was a car that a guy had where he'd swapped in V6 rear brakes, made some modifications to a rear control arm, and was able to bolt on a 15 inch rear wheel. He was also lowered 1 inch. Absent from the description is anything stating the need for specially machined brackets, etc. The details were certainly limited, mainly since there were no pictures available to see the inside hull area of the rear wheels.
My questions now are, why is there a need for a kit to put a 15 inch wheel on? And, might someone have a few images of what this guy may have modified to clear 15" rear wheels?
JBT is offline   Reply With Quote
Old 12-11-2014, 09:02 AM   #2
JBT
Drives: Camaro
Then I found this thread today:
http://www.camaro5.com/forums/showthread.php?t=383641
This topic has been beaten up, but I'd like more specifics on how a person could do it themselves.
Old 12-11-2014, 11:00 AM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
There are quite a few cars with this mod on here. 15" means a lot more sidewall and great for drag racing. V6 brakes are standard with 15" wheels
Old 12-11-2014, 11:00 PM   #4
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
Pm Rhino79, he has done this exact thing and I believe is selling a kit to run a 15" wheel with a modified V6 caliper and modified stock suspension parts.
Camarojt is offline   Reply With Quote
Old 12-14-2014, 06:08 PM   #5
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Originally Posted by Pro Stock John View Post
More sidewall like Mlee said. Low profile tires typically have a stiff sidewall, so not much flex or wrinkle.
Here is a 5th gen with some wrinkle going on:
Mine are 17's though.........
Sent from J-Rod's Continuum Transfunctioner
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 12-16-2014, 05:59 AM   #6
hamilton2008
Drives: 2016 CAMARO SS/ gpi built
Rhino79 just did this a couple weeks ago at work....it was a pretty extinction process, sort of. Wayne DeSellems is our in house fabricator and he had to do a bunch of cutting and grinding but it ended up working out
hamilton2008 is offline   Reply With Quote
Old 12-16-2014, 08:15 AM   #7
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Yeah, Im testing the setup on mine right now. Basically we modded the stock control arm and trailing arm, V6 brakes with CNC machining to give us the clearance. Setup to run 15x10 weld rts wheels.
Rhino79 is offline   Reply With Quote
Old 01-03-2015, 01:51 PM   #8
se7en
Drives: 10 Procharged SS
Did you have to CNC the spindle to make it work? Also was you able to keep the stock E-brake?
se7en is offline   Reply With Quote
Old 01-03-2015, 02:03 PM   #9
Rhino79
Rhino79's Avatar
I didn't have to mod the spindle. Brake cable is on, but it's tight.
Old 01-06-2015, 07:49 AM   #10
ADM PERFORMANCE
Drives: Anything I want
Here ya go
WE HAVE EVERYTHING IN STOCK FOR THIS
We have the best and easiest rear brake kit install ever...no cutting no grinding uing 100% GM PARTS .
ADM PERFORMANCE is offline   Reply With Quote
Old 04-13-2020, 08:48 PM   #11
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
What are the part numbers for the V6 brake portion?
Cornflakes'Camaro is offline   Reply With Quote
Old 04-14-2020, 08:37 AM   #12
62nalide
62nalide's Avatar
Drives: 2013 SS
Best and easy way is to call your dealer or go on GMPartsDirect and you can find every GM part number for V6 brakes
62nalide is offline   Reply With Quote
Old 04-14-2020, 10:09 PM   #13
dadsz28
dadsz28's Avatar
Drives: 5th gen pending
Anyone have info on 1/4 mile reductions with the 15" brakes and wheel set-ups over say a 17" welds and mickeys with stock brakes?
dadsz28 is offline   Reply With Quote
