Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 12-12-2014, 03:39 AM   #1
manumathew
Drives: 2014 camaro zl1
tire suggestions for zl1
Had a set of pirellis after the goodyear. Did around 45k on them. Grip wise they were as good as the oem. Now have around 5k tread left in them, thats more like a month left.
My car is a daily driver does around 300 to 400 k everyday. So milage and cost is an issue.
Has anyone tried a 275 front and 295 rear combo.
Uptil now michelin super sports in the above size seems to be cost effective.
My question is if I change to the above size will it affect my tire alignment and speedo reading.
Also has anyone tried nitto invo...
Advice requested.....
manumathew is offline   Reply With Quote
Old 12-12-2014, 08:38 AM   #2
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Your alignment will be fine. The first number of the tire is the Section Width so that won't affect your speedo reading. The Second number is the height of the sidewall for the tire, this would affect your speedo rating if different, if not you will be fine.
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 12-12-2014, 09:39 AM   #3
manumathew
The second no: is the aspect ratio. So i think a 305/35 wld be havin a different tire height to a 315/35.
Old 12-12-2014, 11:38 PM   #4
brian-nicola
brian-nicola's Avatar
Drives: 2014 ZL1
According to GM anymore than 3% difference will give TC error messages and could cause issues with anti-lock brakes. This is a good calculator
http://tire-size-conversion.com/tire-size-calculator/
brian-nicola is offline   Reply With Quote
Old 12-13-2014, 09:42 PM   #5
Travis104
Drives: 2014 ZL1
Is that 3% overall, or a 3% difference between front and rear tires? I have some some 26 inch MT tires that I was considering, but haven't been able to find if they would cause an issue or not
Travis104 is offline   Reply With Quote
Old 12-14-2014, 08:50 AM   #6
brian-nicola
Drives: 2014 ZL1
Don't know...I assumed they meant overall?
