Old 12-13-2014, 02:01 PM   #1
Lateralus754
Lateralus754's Avatar
Drives: 2012 Camaro 2LT RS
RS Sway Bars Help
I have a 2012 RS that I am considering replacing the stock sway bars on. I've already ordered a 1" eibach lowering spring set.
I was looking at the BMR SB037 kit or possibly just getting some 1LE bars. Any advice that you guys can give me on which way to go or any compatibility issues I may encounter would be highly appreciated.
Also if any of you have done this to your RS how much improvements did you see on the handling of your car?
2012 Camaro RS 2LT
Vitesse Throttle Controller
Elite Catch Can
Solo Match-X-LFX Cat Back Exhaust
Cold Air Inductions CAI
Lateralus754 is offline   Reply With Quote
Old 12-14-2014, 01:25 AM   #2
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
I replaced my front bar with the ZL1 bar and end links. Rear bar is stock v6. Completely different handling. There is an s-bend freeway onramp that used to be scary at 30 MPH from the body roll. I now take it at 55 without any issues.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 12-14-2014, 12:40 PM   #3
Lateralus754
I found zl1 sways off a 13 for sale. Would they fit on my 12 rs without a fuss?
2012 Camaro RS 2LT
Elite Catch Can
Old 12-18-2014, 02:19 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
They'll fit, but you'll also need the front end links. You'll also have to open up the endlink mount on your strut from 10mm to 12mm.
I would personally suggest going with the BMR bars. Having the adjustability is nice for different tire selection and driving styles.
Best regards,
Tyler
888-308-6007
Old 12-19-2014, 01:30 PM   #5
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
BMR.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 12-19-2014, 01:38 PM   #6
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
I am not sure about fitment on the V6 Camaros.
I can tell you that there are differences between the FE3 and FE4 setups.
(I believe the differnces are that 2012+ models have the FE4,which is stiffer.)
I did replace the stock 2010 SS sways with the Pfadt ZL Specs Sways.
Makes a huge difference in handling and responsiveness.
Like what
yzar99 said, I can now take turns at greater speeds, significantly less body roll, and the car instantly responds to commands.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
