Old 12-13-2014, 03:47 PM   #1
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Will zl1 splash guards work on a 2010 Camaro ss with gm ground effects?
Does anyone know or tried if the zl1 splash gaurds will work on a 2010 Camaro ss with the gm ground effects? I have the rpi design ones but rock s and other stuff gets stuck in between and they don't really look that good. Also where can I find some zl1 splash gaurds if they will fit?
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 12-14-2014, 04:29 AM   #2
Cookie Monster
Belle Isle
Cookie Monster's Avatar
Drives: 2014 1LE
Nope. Won't fit properly
2014 2SS
Credit to xVengeancex28
Cookie Monster is offline   Reply With Quote
Old 12-14-2014, 11:06 AM   #3
krisprz2010camaross
Are you sure? Because the accessories guy at my local Chevy dealer said it would but I wasn't really sure.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 12-14-2014, 01:25 PM   #4
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
try showstopper accessories, they have some that fit both zl1 and non zl1 models. you can ask him about the GM ground effects but I think it'll work
TommyTheCat is offline   Reply With Quote
Old 12-14-2014, 05:15 PM   #5
BluePhoenix
BluePhoenix's Avatar
Drives: GMC Sierra AT4
There are aftermarket options that you could probably make work out good.
2020 GMC Sierra AT4 6.2L
WTB - 2010 Camaro 1SS or 2SS, Aqua Blue Metallic, A6
BluePhoenix is offline   Reply With Quote
Old 12-14-2014, 05:44 PM   #6
krisprz2010camaross
I just talked to someone from there and he said that the front will fit but not the rear.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
