Old 12-14-2014, 10:39 AM   #1
mnvaughn
mnvaughn's Avatar
Drives: Camaro
What type of oil do I buy to change my ZL1's differential fluid?
Like the title says, I want to change my differential fluid, but can't seem to find what type of oil I should use to change it.
mnvaughn is offline   Reply With Quote
Old 12-14-2014, 11:25 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
get this 3qts because the differential holds a little over 2qts.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 12-14-2014, 02:56 PM   #3
Swacer
Drives: 2018 GT350
Can go amsoil too
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 12-14-2014, 03:42 PM   #4
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
How do you change it
Sent from Wayne's Manor
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 12-14-2014, 04:06 PM   #5
Stephen12ZL1
Drives: '21 ZLE A10
Driver side of differential there's a drain and fill plug on top of one another. Use a 3/8's ratchet extension as the tool to remove the plugs.
Old 12-14-2014, 07:09 PM   #6
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
Very simple to do. Took less than 30 minutes on mine and that's with jacking the car up.
jayno20 is offline   Reply With Quote
Old 12-14-2014, 11:33 PM   #7
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Make sure you can break lose your fill plug before taking out the drain plug.
ZMEnow is offline   Reply With Quote
Old 12-14-2014, 11:41 PM   #8
YLWJKT
Drives: 2017 ZL1
Don't forget the GM additive; GM P/N 1052358.
YLWJKT is offline   Reply With Quote
Old 12-15-2014, 12:52 AM   #9
NZZL1
NZZL1's Avatar
Drives: 2013 BRM ZL1 Camaro M6
The above Delco 104034 already contains the required additive.
NZZL1 is offline   Reply With Quote
Old 12-15-2014, 12:59 AM   #10
Alfieboy
Madman
Drives: 2017 1SS
Alfieboy is offline   Reply With Quote
Old 12-15-2014, 05:03 AM   #11
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
ZL1 doesn't require the additive if you use the GM lube. "Regular" rears do.
For those rears needing the additive, like our SS, I put a little oil in from the first bottle then put my additive in the oil bottle that I just made room in. Then I added the rest of the first bottle to the car to ensure the entire additive bottle went in.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 12-15-2014, 06:36 AM   #12
NZZL1
NZZL1's Avatar
Delco 104034 = GM 88862624, are the one and the same
Old 12-15-2014, 12:20 PM   #13
nxttruck2002
Drives: Camaro
This is incorrect information.
nxttruck2002 is offline   Reply With Quote
Old 12-15-2014, 12:43 PM   #14
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Probably not if you're in New Zealand. Just like 88862625 is the correct part# for Canada.
change, differential, fluid, oil, zl1
