Old 12-14-2014, 02:49 PM   #1
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
Arrow Does this look right?
I installed my ridetech coilovers and today I was adjusting the dampening and noticed that both struts seem to be leaning to the inside. There's a center bushing and it looks like it's pushed all the way to the side. I haven't got an alignment yet and I made sure that the allen screws were in the right location (for street setting). I'm trying to figure out if this is normal or is there something wrong. The installation was pretty easy and self explanatory.....even a cave man can do it. Any advice or opinions would be appreciated. Thanks
Rico is offline   Reply With Quote
Old 12-15-2014, 09:04 AM   #2
Rico
Rico's Avatar
Drives: Black SS/RS
*cricket cricket*
Old 12-15-2014, 11:39 AM   #3
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Looks like you don't have the optional camber bearing....you have the rubber tops...If so, they will float...get it aligned and you should be fine...
Otherwise, pm Kyle@ridetech if not sure...Good luck....
90503 is offline   Reply With Quote
Old 12-17-2014, 12:51 PM   #4
kyle@ridetech.com
kyle@ridetech.com's Avatar
Drives: 1969 SS/RS Camaro
The bearing uppers are on their way. Let me know if you need anything else.
kyle@ridetech.com is offline   Reply With Quote
