Old 12-15-2014, 08:17 AM   #1
Silver Bumble Bee
Drives: 2010 Camaro 2SS Silver Blk Stripes
Stabilitrack Question
I've read a lot of threads about stabilitrack issues when the service stabilitrack light stays on. My service stabilitrack comes on sometimes when I accelerate hard but it goes off very quickly. Does the system need to be serviced?
The dealer told me they can only determine what is causing the code if I bring it to them without turning the car off. The message does not always show when I accelerate hard but randomly and infrequently. I was wondering if it could be a serious problem that I would need to get fixed under my extended protection plan.
Silver Bumble Bee is offline   Reply With Quote
Old 12-15-2014, 08:35 AM   #2
ELIC1
Drives: black and silver
i had the same issue when the gas sation put in the wrong gas. i ran it down and put in 93 at mobil as was good to go.
ELIC1 is offline   Reply With Quote
Old 12-15-2014, 08:56 AM   #3
TNT523
TNT523
TNT523's Avatar
Drives: 2010 2SS/RS Blk w/cyber grey hockey
Send a message via ICQ to TNT523
I have the same issue after forced induction install. East Coast Superchaging in Cream Ridge NJ installed a Turbonetics 76mm front mount turbo. Under hard throttle it sets off a Service Stabitrak error.. I have had it back to them but it has never really changed. I don't like it cause when I drop the hammer on this thing, I need this stabilitrak stuff right at that time.. Once I let off the throttle everything goes back to normal. No codes on the EMC just that factory error.. I'd love to hear from anyone that knows how to get rid of this... good luck....
TNT523
2010 2SS/RS LS3
Turbonetics 76mm
East Coast Supercharging tuned
Loud Mouth I Axle back
TNT523 is offline   Reply With Quote
Old 12-15-2014, 09:00 AM   #4
Silver Bumble Bee
Hmmm. I use 93 at Texaco. Don't think I've used any other gas in a long time like over a year. I used Chevron before that. Since they merged I use Texaco since those stations are closer.
Old 12-15-2014, 09:08 AM   #5
ELIC1
just saying what happen to me. i have not seen it since. i am sure now that i posted about it, it will come on again lol.
Old 12-15-2014, 12:17 PM   #6
RBL
Drives: 2010 camaro 2SS
It will be very difficult to tell with out it throwing a code, just about anything wrong at all will cause the stabilitrack light to come on.
www.lashwaymotorsports.com
2012 L99, whipple, Roto-Fab, Stainless Power headers, ZL1 fuel pump, cat delete.
RBL is offline   Reply With Quote
Old 12-15-2014, 12:46 PM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
Try holding the traction control button down for 8 seconds before you test.
Without this process Stabiltrak is still active even when traction control is off.
It may just be telling you the tires are spinning and the Stabiltrak is active.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 12-15-2014, 06:32 PM   #8
Silver Bumble Bee
Ted.
When my service stabilitrack light comes on the car is not in competitive driving mode so the stabilitrack and traction control are both on. If I'm just driving in traffic and I accelerate hard the service stabilitrack light comes on sometimes.
According to the owners manual, is it not correct that in competitive mode the stabilitrack is on and the TCS is off so doesn't this mean the service stabilitrack light should not come on even if the stabilitrack is active an the TCS is off?
I did try the 8 second hold you recommended and saw that both the stabilitrack and TCS turned off. I never saw that in the owners manual.
Old 12-16-2014, 08:28 AM   #9
JANNETTYRACING
It is one of those items that is not published in the owners manual.
Misfire due to plug wires or cracked spark plugs will also trigger the stabitrak light to come on.
Ted.
Old 12-19-2014, 05:28 PM   #10
Firehawk178
Drives: 2012 Camaro 2SS/RS Victory Red
Ted.
What timing!!! Coming home from work today my check engine light came on for the first time ever and the car would buck bad and the service stabilitrack light would come on and off.
Went to autozone and they pulled the codes: P0152, 69e(?), P0700, U073, U0100, P0300. Checked to make sure I didn't have any loose plug wires or any touching the headers. Everything seemed fine.
I was going to replace my plugs anyway this weekend. Hope that solves my problems.
Firehawk178 is offline   Reply With Quote
Old 12-20-2014, 07:58 AM   #11
JANNETTYRACING
You may have more problems than spark plugs or wires.
You have a loss of communication between computers over the can bus.
Could be a lose ground.
Ted.
Old 12-20-2014, 11:40 AM   #12
Firehawk178
Ted.
Just changed my plugs and all of the old ones looked good. Going for a test drive now and see what codes are still showing or need to be cleared now.
Old 12-20-2014, 12:34 PM   #13
christianchevell
old school chevy rodder
christianchevell's Avatar
Had a stabillitrac issue a little while this may interest tnt523... the cause was a loose catch can hose had fell off, threw out lean on both banks codes and MAP code and a slew of stabilitrac that would just fade away sometimes... the lack of vacuum registering from the leak..a change in the MAP pressure triggered the stabillitrac to turn off and give the service stabilitrac message..... Apparently things are so interconnected the stabilitrac message can come from just about any damn thing, including low manifold pressure...or in tnt's case...probably high pressure reading in the map.....
Old 12-20-2014, 12:44 PM   #14
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
the stabillitrac light comes on if you break traction.. it's not a problem it is designed that way..
even minor tire slippage will cause it.. if it stays on, then yeah problem, if it flashes on an off it means it detected tire slippage from the speed sensors.
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
