Old 12-15-2014, 09:15 PM   #1
TheBonfiggy
Drives: 2013 Camaro 1LE
Critique My Forged TT Build Please!
Hello everybody! I am about to go through with purchasing the following parts for a build that I have planned, but before I do so, I would like to get the opinion of others and see what you guys have to say or if you would do anything differently. I am planning on going with a forged 416 stroker setup with a Callies 4.0 Dragonslayer Crank, Callies Ultra H-Beam Connecting Rods 6.125", Diamond 4.070 Dish Pistons -22.5cc, and a set of coated clevite main and rod bearings. I am ordering all these parts from TSP and am also having them spec me a custom turbo cam to go along with this setup. As for FI, I am going with the AGP TT Kit with the 54/57mm Journal Bearing Turbos with the .82 a/r. I will obviously be beefing up the fuel delivery system and drivetrain, but does this sound like a solid setup to you guys? My goal is a streetable 1000rwhp car with a useable power curve and I am hoping to eliminate as much turbo lag as possible by going with the 416 stroker motor. Please let me know if there is anything that you guys would recommend doing differently or anything that I could improve on to meet my goals. Any help/advice is much appreciated, thanks!
TheBonfiggy is offline   Reply With Quote
Old 12-15-2014, 10:03 PM   #2
cc-rider
Drives: 2010 Camaro SS
Looks like an incredible set up to me. That forged bottom with the right (lowered) compression will allow you to run those turbos and the tune to places that would be impossible with a stock bottom. I'm not a turbo guru, but my only input would be to make sure those turbos will get you to 1000HP if that's your goal. I'm sure some of the turbo gurus will chime in and confirm...
Do a build thread! I'm subscribed. Cool build...I think you'll do well.
cc-rider is offline   Reply With Quote
Old 12-15-2014, 10:24 PM   #3
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
I beam rods, bigger turbos, meth kit, E85.
Unavowed is offline   Reply With Quote
Old 12-15-2014, 11:31 PM   #4
SuperchargedStealth
Drives: '11 Camaro Supercharged Convertible
+1 on the I-beam rods instead of the H-beam. Look at the Wiseco also instead of Diamond for pistons.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
SuperchargedStealth is offline   Reply With Quote
Old 12-15-2014, 11:32 PM   #5
AGP Turbo
Drives: All things Turbocharged
I would recommend pistons in the -15cc area. With LS3 heads that puts you about 10:1.
This is the new preferred CR area to be in on FI motors. You get a more snappy responsive motor when off boost and spools the turbos a little quicker.
Those 54/57 turbos have done 1024whp in a manual car but that's really all in. And we can do those with the Garrett ballbearing center sections for only $1000 more. It's a solid 10+% faster spool going ballbearing, so if quick response is really important to you, spend a little extra now.
AGP Turbo is offline   Reply With Quote
Old 12-16-2014, 12:28 AM   #6
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Give us a call. I can cut you a killer deal on an entire package price with the Engine, AGP kit etc. Can even work out a deal on install if you are interested.
Frans96ss is offline   Reply With Quote
Old 12-16-2014, 05:35 AM   #7
2010SSRSM6
2010SSRSM6's Avatar
Meth, larger turbos with a larger AR and spend the $$$ on ballbearing turbos.
Squash fuel system, turbo controller and a big ass smile.
Old 12-16-2014, 11:18 PM   #8
TheBonfiggy
Just curios, why do you recommend Wiesco Pistons over diamond?
Old 12-16-2014, 11:22 PM   #9
TheBonfiggy
I was also looking at the 58/62 ball bearing turbos but was thinking lag would be worse with the bigger turbos. Would I notice much of a difference lag wise in the 58/62mm turbos vs the 54/57mm ones?
Old 12-17-2014, 01:02 AM   #10
AGP Turbo
Every little bit adds up, so it is noticeable.
As I think about your build a little more, I'm not sure it's worth going any bigger than the 54/57's because you are on stock aluminum block. In the last year or two it seems like we've seen a lot of LS3 block failures on cars in that 1000+wtq area. It may be hit or miss but bottom line is the LS3 block is not going to be a sure thing with any more power than the 54/57's can put out.
The iron truck blocks with ARP main studs seem to be reliable for a couple hundred more HP. And then anything over that has to be LSX.
Old 12-17-2014, 01:10 AM   #11
SuperchargedStealth
There's good and bad aspects for all pistons, but comparing the 2, Wiseco has the better reputation. Diamond are geared more for the earlier LS models like the LS1/2/6. I like the way Wiseco designed their pistons. Skirts are nice, the top ring is way down and the oil rings are 4 rings and not typical 3. They have a very sturdy ring that sits on the bottom and the rest of the oil rings are assembled on top. This is what was referred to me by TSP. Give them a call and see what they recommend. Let them know where you want your CR to be and what HP you'd like.
Old 12-17-2014, 01:15 AM   #12
SuperchargedStealth
I just built my engine, before you guys really started marketing. If I could do it over, I think I would've gone TT. I'd love to see what these would do on my motor, especially with the Haltech controlling it.
Old 12-17-2014, 01:21 AM   #13
AGP Turbo
It would be soooo sick. Especially with the Haltech to control it all.
Old 12-17-2014, 10:46 PM   #14
SS_TINHO
SS_TINHO's Avatar
Im currently building a stroker 416. Should be done in a month or so…i also have the 54/57 turbos. I'll stop by again and update you on my progress. Goal is a safe 800 RWHP.
13' Camaro SS 746WHP
LSA Supercharged, Built 416 Stroker, BTR Stage III Pd cam, M6, Corsa Exhaust, DMH Cutouts, Vip Modular Wheels, DSE Suspension, Squash Fuel System.
SS_TINHO is offline   Reply With Quote
416, agp, forged, stroker, twin turbo
