![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Mar 2013
TORCO FUEL ADDITIVE FOR MY ZL1
I have been using torco in my Z and also have a dashlogic to monitor the knock sensor while driving. The gas I have been buying is 91 [highest available here] and is straight gas,no ethonal in it. I have been adding one can at each fillup and have had no knock. I filled up yesterday and now I am getting massive knock showing on my dashlogic. I would not think it is bad gas but it is possible as I have been buying gas at the same place for years. I added another can to the tank trying to stop the knock but that did not work.It is still showing massive knock. I am going to drive it real easy now until I burn the fuel all out then try another place I guess. My question is does the torco have a shelf life? I have had the torco for over 8 months now and just used the last 2 cans in the case.
![]() ![]() ![]() Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
I store my Torco in 5 gal pail for years. No problem unless stored in a container the sun can get threw. After adding two cans and still getting knock you should get your car checked out.
#3 | |
Hide! My wife's coming!
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2011
Is your car modded? I'm assuming it is. We have 93 here in TX and I've been filling up at the same gas station for years and when I got my ZL1 I started having knock. Changed to Chevron and it got better. Adding Torco helped eliminate that issue.
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
![]() Drives: 2011ShelbyGT500 Join Date: Jan 2014
I believe Torco has a shelf life of 2 years, I use 1/2 can with 93 octane in my Shelby on every fill-up.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Silly question, but have you tried unplugging/resetting the Dash Logic? See if maybe it is not getting an accurate/valid reading?
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
#6 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
How much KR is "massive"?
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
#7 |
![]() ![]() ![]() ![]() Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 GT350 Join Date: Nov 2011
Is the Torco necessary for a unmodded Z?
Most of the gas we have around me is 91 grade.
Off to the Dark Side
#9 |
Going for Plaid
No it's not necessary.
#10 | |
![]() Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z Join Date: May 2009
Here is a recent article on additives. http://www.lsxtv.com/features/pri-co...he-next-level/
- Buttons and Skulls -
miss my annimated signature. |
#11 |
Thank you guys
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
It makes no sense to me why we don't have 93 in Oklahoma. I know of ONE station I can get it at.
#13 |
Any gas station can get a load of bad gas. If a terminal ran their tank down and didn't draw the water off the tank the truck could load some water. Another issue is ethanol settling out in the gas station tank. Ethanol raises the octane of the fuel so generally a lower octane gasoline is blended with ethanol to make the final octane. If the ethanol settles out (generally binds with water) you're left with lower octane gasoline.
2014 ZL1 |
#14 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
Happened to me also when I went to a hole in the wall gas station. I went home and siphoned it out and gave it to the lawn guy. went to my usual filling station and got the good stuff and all is well.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
