Old 12-18-2014, 07:32 PM   #1
fatboy99
fatboy99's Avatar
Drives: 2014 Camaro 1LE
6 speed Manual tranny problem
6 speed tranny problem
Driving car today encounter problem with transmission (6 speed manual) only allowing shifting into 1st, 4th & reverse. It is as though tranny is stuck in shift skip mode, though that's not showing up on dashboard screen. Even if car was turned off you could not find any gear but 1,4 and reverse. Any ideas on problem?
fatboy99 is offline   Reply With Quote
Old 12-18-2014, 08:24 PM   #2
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Sounds like bent shift forks, however your car is under warranty so you just need to take it to the dealer and let them worry about it.
Old 12-18-2014, 09:34 PM   #3
shippingguy
Drives: 2024 Black ZL1, M6
There is a recall on the tranny. I got a notice from GM. Something about a retaining clip being installed properly. If not it can lock you out of gears.
shippingguy is offline   Reply With Quote
Old 12-18-2014, 10:17 PM   #4
Edge1
Drives: 2013 AGM 2SS/RS 1LE
same thing happened to me....take to the dealer and they will fix.
Edge1 is offline   Reply With Quote
Old 12-19-2014, 01:30 PM   #5
shippingguy
Here is the letter I got.
Old 12-19-2014, 01:42 PM   #6
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Noob question, but could this be caused by a malfunction of the 1-4 CAGS shift program?
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 12-19-2014, 01:52 PM   #7
markgws6
markgws6's Avatar
Drives: 2019 Chevy Equinox Premier AWD
Sometimes, when I shift from 1st to 2nd, even though I have the skip shift eliminator installed, I swear I can feel it trying to force a shift to 4th...
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
markgws6 is offline   Reply With Quote
Old 12-19-2014, 09:29 PM   #8
fatboy99
fatboy99's Avatar
Guys I think it is a computer / electrical glitch.. Or maybe along the lines Spartan01 suggested... I unhooked negative batt cable for a couple hrs yesterday and reinstalled cable and problem went away. (Gremlins) Drove car last night and today approximately 150 miles and so far no problem. Of course it's in the back of my mind if and when will this problem will reoccur. Talk to dealer and said they've not encounter this before. ( of course). So for now I'll drive the hell out of it and not worry about it. If it happens again then to the shop it goes, as I would not know where to begin to diagnose. Thanks for input from everyone.
