![]() Drives: 2014 2ls Join Date: Nov 2014
Aftermarket Rims
Do they cause any issues with the TPMS? Or does it depend on the aftermarket rim? Is there a way to check?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
didn't bother mine
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
Drives: black and silver Join Date: Apr 2014
all depends on who puts them on
Even if they jack it up, there is a repair kit for the sensors on the Camaros that is only a few buck a wheel unlike others where the entire TPS has to be replaced.
probably going to bring it to firestone tomorrow if the wheels are delivered on time.
#6 |
To the guy that says "didn't bother mine is lying. On my 2011 RS/SS I up graded to a set of 22"s. which had there own TPMS/valve stems. The system on the car only reads the GM factory ones. So if you plan to upgrade, get the same ones from GM or biggest problem will be you will constantly have TPMS fault warning on your heads up display. Good thing is you can clear it out by pressing the menu button on the turn signal indicator.
#7 | |
#8 |
Because "DickHead" some people want to keep the stock rims and tires for possible future use or sell them.
#9 |
Drives: 1967-2014 Camaro's Join Date: Jun 2010
We offer a pre-programmed TPMS for the 5th Gen specifically, and it is OE replacement quality that could help if you need to change out sensors
http://www.rickscamaros.com/camaro-l...2010-2013.html PM if you have any questions |
#10 |
Then tell me how I lied puzzy boi.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
And we're off to the races...
![]() Currently the scores are tied at 2-2, can the veteran Camarocracka hold his own against this new upstart Mr. Jgunn65? This is still anyone's game. Step right up and place your bets...
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
#12 |
![]() Drives: Jeep Join Date: Jun 2014
Stock TPMS
Im using the factory Camaro sensors from my stock wheels on my 20" aftermarket wheels, no problems at all...
#13 |
![]() Drives: 2012 Camaro SS/RS Join Date: Aug 2013
great thread! right about X-mas time too love it!
#14 |
oh snap. thanks for the actual answers. hoping i dont have any issues.
