Old 12-19-2014, 01:58 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Which Color Parts did you go with?
Counting Down the days till i purchase the rest of my suspension goodies and the questions is.. Which color do i go with? lol. Red or black from BMR? Which color did you go with!
My maro is black with white stripes and matte black ZL1 wheels!
Whats your opinion?
Nighthawk89 is offline   Reply With Quote
Old 12-19-2014, 02:18 PM   #2
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
I went with all red bmr stuff...my car is all black...so it was nice contrast even though you cant see any of it hahaa
13blackLS is offline   Reply With Quote
Old 12-19-2014, 02:29 PM   #3
Nighthawk89
Im contemplating the red at this point....
Old 12-19-2014, 05:02 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Red looks good under there and really makes the parts you've replaced stand out. I'm more of a subtle person though, so I'd probably go with the Hammertone Black.
Best regards,
Tyler
888-308-6007
Old 12-19-2014, 05:22 PM   #5
Nighthawk89
Best regards,
Tyler
888-308-6007
Decision's Decision's...
Old 12-19-2014, 05:23 PM   #6
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
Went with all hammertone just thought red would not look good on a blue car.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 12-19-2014, 05:25 PM   #7
camarossdusk
whippled 5th gen
But like tyler im not into flashy.
Old 12-19-2014, 06:57 PM   #8
Nighthawk89
Im leaning towards hammertoe after reviewing a few pictures.. My solid subframes are black as well so idk if i want just a few pieces red. it'll look kinda goofy. plus the coilovers i want are a darker color (Ridetech).
Old 12-19-2014, 09:08 PM   #9
camarossdusk
whippled 5th gen
[QUOTE=Nighthawk89;8122738]Im leaning towards hammertoe after reviewing a few pictures.. My solid subframes are black as well so idk if i want just a few pieces red. it'll look kinda goofy. plus the coilovers i want are a darker color (Ridetech).[/QUOTE nice was real happy with way mine turned, out cant completely get away from red, since the sb039 sway bars have red bushings, as well as the cradle bushings.
Old 12-20-2014, 02:19 PM   #10
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
It's common knowledge that anything red added to the car makes it faster!
Old 12-20-2014, 02:36 PM   #11
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
Apart from the LCA's you cant see them unless you get under the car. Just buy whatever's cheaper.
Powhusku is offline   Reply With Quote
Old 12-20-2014, 04:24 PM   #12
Nighthawk89
Which exhaust is that?
Old 12-20-2014, 04:28 PM   #13
Powhusku
Powhusku's Avatar
Corsa's 3" ZL1 catback.
Old 12-20-2014, 06:51 PM   #14
Nighthawk89
I likey, who did you go thru for thoes? I noticed that "hookers" is coming out with a axle back version.
