Old 12-19-2014, 09:09 PM   #1
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
Pics from bmr suspension mods
Been trying to get some pics posted Name:  image.jpg
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 12-19-2014, 09:15 PM   #2
camarossdusk
whippled 5th gen
Another pic Name:  image.jpg
Old 12-19-2014, 09:18 PM   #3
camarossdusk
whippled 5th gen
Old 12-19-2014, 09:20 PM   #4
camarossdusk
whippled 5th gen
Old 12-19-2014, 09:22 PM   #5
camarossdusk
whippled 5th gen
Old 12-19-2014, 09:43 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Great Job! I did the changes too -- but didn't replace the cradle bushings -- just the inserts -- and only had to 'lower' the cradle -- you took yours' out -- that's awesome!
Are you also replacing the upper control arm bushings?
A++++ for taking out the cradle!
-Don
Old 12-19-2014, 10:09 PM   #7
camarossdusk
whippled 5th gen
thank you yes was a lot of work but well worth was lucky enough to have access to a lift, yes also replaced the upper control arm bushings.
Old 12-20-2014, 12:07 AM   #8
hammdo
hammdo's Avatar
Yep, that is the way to go. I didn't need to do the full bushings, but did all the upgrades -- lower control arms (FE4/1LE), BMR Adjustable Toe and Trailing arm/bushings, uppers, 1LE shocks/Struts, sways front and rear, and radius arm inserts.
HUGE difference in the handling --
I didn't have a lift so it was all on jack stands -- still, taking out the cradle is something...
Congrats!
-Don
Old 12-20-2014, 01:40 PM   #9
camarossdusk
whippled 5th gen
yes your a right on makes a big difference in handling, I needed the full cradle bushings for the bad wheel hop was getting with pushing 750-800 hp.
