Old 12-20-2014, 10:22 AM   #1
johnjohn
johnjohn's Avatar
Drives: 2010 ss
what did i do wrong here???
after installing a set off lower coils i got this???
2010ss L99 to a ls3 s480 turbo lil john cam tuned by james short
johnjohn is offline   Reply With Quote
Old 12-20-2014, 10:23 AM   #2
johnjohn
johnjohn's Avatar
Drives: 2010 ss
sorry for the upside down pic
Old 12-20-2014, 10:53 AM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
It's normal for them to stick up some, not sure it should be that much though.
Build Journal
Old 12-20-2014, 11:14 AM   #4
jrhagen
Banned
Drives: Camaro
Is the car on the ground?
jrhagen is offline   Reply With Quote
Old 12-20-2014, 02:16 PM   #5
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I think it's the inverted pic and low angle making that gap look a little big.
This is a very common panic reaction after setting your car back down and really looking at those strut tops, LOL.
It is normal!
Old 12-21-2014, 09:47 PM   #6
johnjohn
johnjohn's Avatar
Drives: 2010 ss
ok guys ya its on the ground
Old 12-21-2014, 10:15 PM   #7
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Are both sides about the same? I can't remember if there was big washers on the top of the strut rod, but I think there was. Did you pay attention to the order of all the parts when you took it apart?
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 12-21-2014, 11:15 PM   #8
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Completely normal.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 12-22-2014, 12:48 AM   #9
X25
X25's Avatar
Drives: '16 C7 Z51
Originally Posted by yotaman96 View Post
Completely normal.
+1 mine also look the same.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 12-22-2014, 07:06 AM   #10
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
again, normal. Nothing to worry about.
Old 12-22-2014, 09:26 PM   #11
johnjohn
johnjohn's Avatar
Drives: 2010 ss
thanks guys ya i put it together same way it came apart
