Old 12-21-2014, 10:35 AM   #1
SSNYSTR
SSNYSTR's Avatar
Drives: Black 2011 Camaro 2SS
Best Drag Radial
I have the ZL1 replica rims, 20x10 rear, what drag/street radial would be best on the track? I currently have 305 NT555Rs. Looking for something better when these wear out. I was thinking NT05Rs. I heard that MT ET Street would be good, but they don't make 20".
SSNYSTR is offline   Reply With Quote
Old 12-21-2014, 10:38 AM   #2
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
http://www.mccormackracing.com/cgi-b...y=ID&order=123
Old 12-21-2014, 12:01 PM   #3
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
I run Mickey Thompson ET streets on mine. 305/35/20 on an 11" wheel. Great tire, but they're not cheap.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 12-21-2014, 12:20 PM   #4
white ZL1
Drives: none
305/35-20 M/T ET Streets.
white ZL1 is offline   Reply With Quote
Old 12-21-2014, 01:07 PM   #5
SSNYSTR
SSNYSTR's Avatar
Street Radial ll?
Old 12-21-2014, 01:26 PM   #6
UF4LIFE102SS
Drives: 2010 2 SS
Originally Posted by BigDame1 View Post
Street Radial ll?
Yes did u click on the link I posted scroll to the bottom 305-35-20.
Old 12-21-2014, 01:29 PM   #7
12 ZL1 #1725
12 ZL1 #1725's Avatar
Drives: 2012 ZL1 Black 6M
I've had both....the MT and NT05R..... IMHO no contest the MT's are SUPERIOR BY FAR!!!!
Sit Back and Enjoy The Ride!!
12 ZL1 #1725 is offline   Reply With Quote
Old 12-21-2014, 02:15 PM   #8
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I was thinking MT had a new tire out that took the place of the street radial II...
MODS:
Old 12-21-2014, 03:49 PM   #9
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
M/T=M&H>Nitto
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 12-21-2014, 04:16 PM   #10
MRREVINTO7
Drives: 14 1Le --14 chevy ss sedan 07shelby
been 10.20 on NT05Rs ..Nuff said ..thats all i run now plus they work well in twistys with 34psi in em
MRREVINTO7 is offline   Reply With Quote
Old 12-21-2014, 04:58 PM   #11
elarson5757
Obsessed and Loving It...
Drives: 2013 1LE-SS
Why do the MT Streets say for auto transmission vehicles only?
elarson5757 is offline   Reply With Quote
Old 12-21-2014, 05:13 PM   #12
yotaman96
yotaman96's Avatar
Technically, they work better with an auto because it's less shock to the tire. A slick would work better with a manual. That being said, I run the ET Streets on both my manual cars.
2002 Trans Am
Old 12-21-2014, 05:15 PM   #13
Cat988h
Cat988h's Avatar
Drives: Rally yellow 2011 Camaro 1SSRS
The main reason they say that is because they do not like or recover from the shock of a m6 dumping the clutch. A bias ply tire will suck up the impact and recover much better than a radial tire. They will work great just don't shock them with a dump of the clutch, slip it out a little. I have a new set of 305/35/20 coming in the mail should be here for x-mas. Here is a good read that goes into further detail.
http://www.dragzine.com/tech-stories...-drag-radials/
ATI Super Damper, Katech C5R Chain, Jannetty 470 Comp Cam, Comp Valve Springs, Mellings Oil Pump, Manley Push Rods, Comp Tringion Upgrade, Cold Air Inductions Intake, 1-7/8 American Racing Headers w Cats, MBRP 3 Inch Exhaust, RX Catch Can, Eaton Tru Trac, 3.91 OEM, DSS Drive And Half Shafts, LPW Diff Cover,3 Inch Noweeds, Amsoil Z-Rod, Tuned by Jannetty Racing
Cat988h is offline   Reply With Quote
Old 12-21-2014, 09:16 PM   #14
Merc
In The Circle
Merc's Avatar
I run Hoosier slick's on Pumpkin (M6) 1.60 60's @11.72(Bolt On's Only) Work Awsome.
