Old 08-24-2009, 09:27 AM   #1
monza66mo
Driving daily
monza66mo's Avatar
Drives: '17 2SS
Question K&N oil filter - lower oil pressure?
2500 miles on my L99 so I had the oil changed. Mobil 1 w/K&N filter. Seems that the oil pressure is lower. Not dangerous but noticibly lower. At idle, the PSI goes down to about 20.
Anyone else notice lower pressure after the 1st oil change?
Art in Missouri
monza66mo is offline   Reply With Quote
Old 08-24-2009, 09:33 AM   #2
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Who changed the oil?
Old 08-24-2009, 09:52 AM   #3
shevyman
Drives: 2010 Camaro SS IOM
weird. i was told by a friend that purple oil or whatever will do that maybe its the oil you chose or they put in the wrong one if it wasnt you who did the oil change. maybe the filter has something to do with it.
shevyman is offline   Reply With Quote
Old 08-24-2009, 09:55 AM   #4
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Was this your first oil change? If so, I would look at the old filter being clogged up with silicones and metal debris from the break in.
Thus increasing your oil pressure a bit, but alleviated.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 08-24-2009, 09:57 AM   #5
Banshee
Banshee's Avatar
And 20 PSI at idle is fine. Also, you reading the gauge at cold before and hot now? Just a thought..no insult intended.
Old 08-24-2009, 11:10 AM   #6
monza66mo
Driving daily
monza66mo's Avatar
Drives: '17 2SS
No insult taken... I think it is just a matter of I didn't notice the pressure before. It may have been this way all along but after I changed the oil, I am more apt to look at the gauge.
Yes, this was the 1st oil change... probably as you stated... new K&N filter, no restriction.
I just thought it was interesting so I brought it up for discussion.
Art in Missouri
Old 08-24-2009, 12:42 PM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
You are fine same thing in my car and it has all most 10,000 mi on it.
Old 08-24-2009, 01:39 PM   #8
BAD BRAD
Drives: 1969 CAMARO 2010 CAMARO
not trying to start any trouble but when ur oil filter is clogged up. this does not cause more oil pressure all new filters have a bypass built into them pressre is created by oil pump and other parts in motor.
BAD BRAD is offline   Reply With Quote
Old 08-25-2009, 12:01 AM   #9
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Mobil 1 has several different viscosity ratings, plus regular and Extended performance. Chances are they put in something with a lower viscosity rating.
HeavyD is offline   Reply With Quote
Old 08-25-2009, 11:26 AM   #10
Banshee
Banshee's Avatar
He had higher pressure before oil change..he changed oil and pressure went lower.
I did state that after the debris and silicones clogged up the filter, thats why the higher pressure..yet lower when he changed oil/filter.
Yes, probable that bypass took care of some of that if filter is extermely bad or to prevent a failure, but the element in my first change was saturated with aluminum and iron. with a gradual decrease in efficiency, you may see a pressure increase..the bypass prevents catastrophic failure at a set predetermined value. You can have a decrease in efficiency and an increase in pressure way before the bypass valve operates.
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
