Old 12-22-2014, 06:16 PM   #1
Stew
Drives: 92 Luminadead/01 Dakota/97 F150 4x4
Need help with 99 Silverado Z71
I bought a Silverado and am in need of a new ignition. Problem is that GM apparently offered 4 different ignitions on them in 99. I was wondering if anyone here would be able to look it up in a GM service system and tell me what ignition I need with the VIN. it would be greatly appreciated!
Stew is offline   Reply With Quote
Old 12-23-2014, 09:17 AM   #2
Stew
ttt
Old 12-23-2014, 12:56 PM   #3
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Which body style do you have? 1999 was a transition year for the Silverado. Do you have the '88-'99 style or '99-'07 style? The older style will have a 5.7 350 engine with a distributor ignition and the newer style engine (5.3/4.8) has a coil pack on each cylinder. This is probably why there are 4 different ignition systems offered in 1999........
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 12-23-2014, 01:49 PM   #4
Stew
Inever considered that! it is the new style with the 5.3. What I can find though shows there are multiple ignitions for the newer 5.3 model.
Old 12-24-2014, 02:07 PM   #5
LimaCharlie
I would go to the parts department at your local Chevy dealership, give them your VIN, and get the part numbers for the coils (if that is the issue you're having). If you like the price, get them there. If not, at least you now have the part numbers and you could look somewhere else.
