Old 12-23-2014, 01:46 PM   #1
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Front Swaybar without Endlinks
Thinking of getting a front swaybar to improve my DD handling a little without upgrading the end links. Was leaning towards the BMR swaybar and installing it on the softest setting. Any comments about upgrading the sway without upgrading the endlinks for a DD.
camguynj is offline   Reply With Quote
Old 12-23-2014, 01:56 PM   #2
BMR Sales
BMR Sales's Avatar
Drives: Race Car
You "can" upgrade the front sway bar without upgrading the end links. You just risk the possibility of bending or breaking the factory links if you hit a big bump or pot hole. The stiffer sway bar puts additional stress on the somewhat "wimpy" factory end links, so we do recommend upgrading the end links, but it is not 100% mandatory!
The bigger question is....why the front? The 5th Gen Camaro will benefit more from upgrading the rear sway bar, which will help with the understeer seen with the factory bars. So, unless you already have an aftermarket rear bar, my recommendation would be to upgrade the rear first....if you can only do one. Of course, it would be better to upgrade both to balance the front and rear out at the same time, but I understand that sometimes that is not in the available budget!!!
Old 12-23-2014, 02:11 PM   #3
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
^^I agree with BMR. The 5th gen Camaro is known for its bad understeer and a bigger rear sway bar will remove some of the understeer tendencies.
The good news is your 2013 SS has the FE4+ suspension which means it has the stronger end links (12mm studs compared to the earlier 10mm studs). You have the same end links as the 1LE, ZL1, and Z/28 (I believe). They will resist bending more. For a DD, I think you will be OK with the stock end links. However, if you start doing autocross or road course racing, I would consider getting better end links.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 12-23-2014, 02:59 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
The 13+ do have stronger endlinks so changing them out is not as important as 10-12, but it's still a good idea.
I would also recommend doing both sway bars at the same time. Your car will already understeer at the limits and a front bar will only make that worse. A rear only can be potentially dangerous as it may introduce oversteer. Sway bars are really about balancing, so I highly recommend doing both front and rear even if you have to run OEM endlinks for a while.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 12-23-2014, 03:53 PM   #5
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
All GREAT advice.
From everything I have seen and read over the years being on the forum is, ends links are a nice to have change if money is no object, or if you are tracking the car (road course, SOLO events, etc.) Otherwise the stock end links will hold up fine. Run them and use them until you are forced to replace them. Save the few hundred dollars for other more important mods.
Old 12-23-2014, 06:19 PM   #6
camguynj
camguynj's Avatar
Thanks for clarifying, much appreciated.
Old 12-23-2014, 06:22 PM   #7
camguynj
camguynj's Avatar
Thanks for that info!
