Old 12-24-2014, 11:11 AM   #1
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Going sideways!
Every time I get on the gas the tires break lose and want to go sideways. I suspect it's a suspension issue, correct me if I'm wrong. What can I do to make it trac straight? Any input is appreciated.
11TexaSS is offline   Reply With Quote
Old 12-24-2014, 12:01 PM   #2
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
normal. Once the tires are spinning there's nothing keeping it in place so it's free to drift
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 12-24-2014, 12:12 PM   #3
11TexaSS
11TexaSS's Avatar
Dang, I was hoping there was something I could do to keep it kinda straight. Though maybe it was due to flexing in the suspension.
Old 12-24-2014, 01:25 PM   #4
caper
Drives: 2010 IOM 2ss/RS
Have you never driven a fast car? That's part of the fun lol
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 12-24-2014, 01:37 PM   #5
forklord
forklord's Avatar
Drives: 2010 2SS
troll or serious? lol....stock tires are absolute garbage for one. stock bushings, struts, etc....all crap.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 12-24-2014, 01:45 PM   #6
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
I would start with some sticky tires, then start working on rear suspension would be my best advice for you.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 12-24-2014, 02:10 PM   #7
11TexaSS
11TexaSS's Avatar
I'm running Vredestein 315 in the rear which have decent traction but do very little with a Maggie. I get no wheel hop which is good. I guess chassis stiffening is in order.
Old 12-24-2014, 04:15 PM   #8
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
Do you have any suspension mods?
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
Old 12-24-2014, 04:39 PM   #9
camarossdusk
whippled 5th gen
i didn't start getting wheel hop until went over 700 rwhp, if your not getting wheel hop, I would look at trailing arms, and toe rods, those helped a lot from going sideways, also the rear adjustable sway bar helped a lot too, control arms is suppose to help too, I went all bmr suspension mods. I have 315/35 nto5r drag radials which helped me a lot.
Old 12-24-2014, 04:45 PM   #10
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Are you auto or manual? I got bad hop bone stock, put on Spohn trailing arms which helped a lot.
camguynj is offline   Reply With Quote
Old 12-24-2014, 05:02 PM   #11
X25
X25's Avatar
Drives: '16 C7 Z51
Just by a FWD car and it will go straight when you break traction, including at the corners : )
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 12-25-2014, 02:19 PM   #12
camarossdusk
whippled 5th gen
I have a 6 speed, no problems when I was n/a, started running into more wheel hop when went boosted.
Old 12-25-2014, 02:21 PM   #13
camarossdusk
whippled 5th gen
I have the bmr adjustable trailing arms.
Old 12-25-2014, 04:01 PM   #14
Quicksilver 1LE
Quicksilver 1LE's Avatar
Drives: 14 1000HP SS/RS 1LE
What he just listed. I hit up Tyler on this forum and he suggested the same suspicion parts to correct mine. I have Michelin Pilot Super Sport tires and having 576rwhp/540rwtrq breaks the tires loose in first through third.
Quicksilver 1LE is offline   Reply With Quote
